96 4runner soft brake pedal
Old 07-14-2014, 05:50 AM
roland750's Avatar
I recently had a leaking rear wheel cylinder. After the brakes were replaced I've had a inconsistent brake pedal which leads me to believe that there is air in the lines. I have ABS so I've done some research and found some info for bleeding brakes for a later model Gen3 with ABS and was wondering if this procedure applies to earlier Gen3.
File Type: pdf
Old 07-21-2014, 10:29 AM
Just_Me69's Avatar
Why wouldn't it? Just bleed the brakes like normal. Probably starting with the rears; where the problem started.
Old 07-21-2014, 11:48 AM
JasonYota's Avatar
X2. Bleed them in the correct order though.
06-01-2021 01:51 PM
87turboPA
07-12-2015 07:49 AM
Kalihi,HI
07-09-2015 04:29 PM
Jnkml
07-06-2015 01:20 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: 96 4runner soft brake pedal
