96 4Runner Overheating but not really - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-10-2004, 08:58 AM   #1 (permalink)
Hi,
I have an issue was my car lately. It's been in the shop 3 times this week and the problem has not been solved. The temp guage creeps up beyond the 1/2 way point after about 1/2 hour of driving whether on local roads/bumper to bumper traffic or 60+ miles per hour on highway. After pulling over for 10 minutes, the car is fine to go. The temp drops back down to normal. If the car is indeed overheating, how can I possibly drive it after pulling over for 10 minutes? I had the temp guage replaced twice, radiator flushed and cleaned out. My next move will be to replace the sensor. I don't know what else to do.
96ToyotaWoes is offline
Old 09-10-2004, 09:36 AM   #2 (permalink)
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Send a message via AIM to Rick F. Send a message via Yahoo to Rick F.
What about the obvious stuff like replacing the thermostat, power flushing the system (not just the radiator), fan clutch, checking for hoses collapsing...
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09
'08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks
Rick F. is offline
Old 09-10-2004, 09:41 AM   #3 (permalink)
PoBoy's Avatar
When it starts to over heat...Turn on the heater on full blast and see if it goes down...it should. If it doesnt, then it could just be the sensor. It it does go down...then yeah, you're overheating.
__________________
So I sold my '96 4Runner to get married...I was sad. BUT NOT ANY MORE!
Check out my 1985 4Runner with 32,xxx miles!
PoBoyTech.Net
PoBoy is offline
Old 09-10-2004, 09:48 AM   #4 (permalink)
Steveh29's Avatar
I had a similar problem and it ended up being the radiator. The faster I went the hotter it would get. Then at rest, the car would cool down fairly quickly. The radiator was clogged and not able to dump the heat. Be sure there's nothing blocking the radiator vanes or clogging airflow. Also check to see no weatherstripping or shrouds used to duct air into the radiator are missing.
__________________
Steve
1995 4Runner - V6 - 5 Speed
Rear ARB, Manual Hubs, Front TruTrac, Marlin Transmission, ARB Front & Sonoran Steel Rear bumpers that have saved my life!!
Steveh29 is offline
Old 09-10-2004, 08:36 PM   #5 (permalink)
fromjeeptotoyota's Avatar
try replacing the radiator,water pump, and thermostat
most common problems.
Quote:
fromjeeptotoyota is offline
Old 10-08-2004, 09:42 AM   #6 (permalink)
Well I ended up changing the radiator. It was 80% clogged. Not happy about the $$ I've spent to fix this problem. Now, the thermostat is always at the half way mark but doesn't go beyond that. That's a good thing but I do not recall my car running that hot, ever. The thermostat is usually a little below the half way mark. Does it sound like my problem has been fixed once in for all? Or should I bring it back and have it re-checked? Thanks for all your help.
Old 10-08-2004, 09:57 AM   #7 (permalink)
lee
lee's Avatar
Send a message via AIM to lee
mine is almost always at the half, not really above or below.
lee is offline
Old 10-08-2004, 10:03 AM   #8 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
If your radiator was that plugged you might consider changing the thermostat and waterpump as well if you really want to be absolutely sure everything is functioning 100% (also check for any blocked hoses and such too). Mine stays just below the halfway mark but it will depend on what part of the country you live in too.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Tags
1995, 1996, 1997, 4runner, 96, boise, check, clogged, craigslist, heating, hot, overheat, overheating, pulling, radiator, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
85 4runner overheating.. HOW??? 9-Hood 84-85 Trucks & 4Runners 6 12-17-2005 08:15 AM
96-96 4runner turn signals as Daytime Running lights?? ASU4runner 95.5-2004 Tacomas & 96-2002 4Runners 1 04-07-2005 11:03 PM
86 4Runner overheating pruney81 95.5-2004 Tacomas & 96-2002 4Runners 1 02-03-2005 10:39 PM
4Runner overheating Dez 95.5-2004 Tacomas & 96-2002 4Runners 6 02-09-2003 03:49 PM
2009 InternetBrands, Inc.
