96 4runner 1500-2500 rpm rattle: HELP!
Old 09-21-2008, 01:25 AM
ulricr's Avatar
Ive got a 96 4runner(auto). it runs great except for a rattle that seems to come from under the truck, right about the driver seat area.i can hear it when i go up a hill, when i accelerate, any tiem the rpm hits 1800 or 2200. it sounds like a drumer hiting on an aluminum plate. i checked all the heat protectors i could see, and it just passed a mechanincal inspection for me to get it plated, and the mecanik didnt see anything wrong under the truck. WHAT COULD THIS BE?
Old 09-21-2008, 02:57 AM
lookin4fish's Avatar
I will speculate the u joints in the drive shaft. seems to have been the same thing i was expierencing when mine went bad. mine was so bad i could just grab on it and shake it and could tell the drive shaft was bad. I confirmed it by jacking it up and having someone push on the gas while i watched, but for saftey reasons this is not wise!
Old 09-21-2008, 04:40 AM
ulricr's Avatar
the drive shaft for the rear does move a little. I guess its hard to explain the tun rattle sound just with words. It seems an odd sound for a drive shaft. But I will check again. If anyone has suggestions, feel free.
Thanks looking4fish,hope you catch some!
Old 09-21-2008, 07:17 AM
ulricr's Avatar
I just checked the u joints and drive shaft, all is perfect. no play or leaks.i took a wrench and tapped along anything that could be tapped, and i found nothing. this is baffling!
Old 09-22-2008, 02:11 PM
I had the same thing happening on mine… It was a catalytic converter. It was still functioning fine but would rattle under load, just as you have described.
Old 09-23-2008, 10:39 AM
Ron Helmuth's Avatar
similar symptoms
I had similar symptoms on my 95 2nd gen. Had to unbolt the cat and literally turned it upside down and shook out a piece of metal-muffler guys implied it was unburned fuel that had solidified in the cat... sure enough the rattle was gone.
They did similar method as looking4fish describes-someone was under the cat while another tech "goosed" the accelerator-they then showed me same thing to get my permission to drop the cat and shake it out.
Old 09-26-2008, 03:26 AM
ulricr's Avatar
heh thanks guys. i will get under there and check it out.
cheers...
Old 09-26-2008, 04:14 AM
Team420's Avatar
Marbles in a coffee can, thats usually what it sounds like.
Old 09-26-2008, 06:19 AM
DOT3's Avatar
Make sure your hand brake cable is properly adjusted.
Old 09-26-2008, 12:54 PM
05prerunner's Avatar
mine was doin that as well - it was the shield around the cat converter, the bolt had come out so i rigged up some poly spacers with new bolt and rattle is gone
Old 09-28-2008, 08:47 PM
4Runnin4now's Avatar
Same here. Mine was the heat shield around the cat. I took my shield off and the rattles went away.
Old 09-29-2008, 05:14 PM
ulricr's Avatar
Is it a hard job to do? Can i handle it with a simple tool set and the hanes manual? If i take off the heat cover, is that dangerous, should I replace it? Thanks brothers. You really got my back on this, and thats cool!
smthwsn357
12-04-2023 02:08 AM
icentropy
09-16-2020 02:47 PM
cars-guy
07-11-2015 07:51 PM
88runnergomas
07-09-2015 01:12 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 96 4runner 1500-2500 rpm rattle: HELP!
