96 4 runner tranny swap question
My 4runner has 185,000 miles and I've just replaced the tranny with a 2000 tranny with 60,000 miles. So far the only issue is a rough shift when put into drive. BTW, both trannies are automatic. All other shifts are shifts are fine including rev, neut, 2nd, 3rd, 4th, etc... Any ideas? Thanks.
I got it from a part out. Ok so what do I need to know if the trannies are different. Obviously it fit and I have been driving it for over 1000 miles. The only issue I see is that moving from park to drive gives a little jolt but nothing major just a little more than expected and when it switches from 1st to 2nd too. Other than that the upper gears are smooth shifts. What do you suggest?
BTW, it is a 4wd.
BTW, it is a 4wd.
I will talk to a buddy of mine who has alot of experience in interchangeable parts. Will post what I find out tomorrow. You may have to change out some computer controls from old one to work correctly.
Thanks
Thanks
http://townhall-talk.edmunds.com/direct/view/.f0b352e
'Electronic Controlled Transmission' Could have something to do with it since it moves the shift points if the 96 has a different set on points.
That's what I was thinking...maybe resetting the ecu or replacing it...just a thought but I'll look into it further...
What am I looking for in that link...and btw...thanks.
It talks about the different options. www.car-part.com only lists transmissions up to 1999 that will work on the 96. I will ask my buddy tomorrow and post as I said.
Ok I visited the site and it looks like the 2000 model tranny is not compatible with anything but a 2000 and in a couple cases a 99. Interesting. I hope that website is incorrect. Thanks for your help on that helpful site.
FYI, I've been driving the 4runner and so far so good...except a little bit of a rough shift it seems fine. In fact this weekend I drove it with the wife and kids from San Antonio to S. Padre Island (over 650 miles total) and had no issues other than those mentioned. I'll update with anything new.
GreenLion
06-07-2021 10:49 AM
stagger_lee
03-29-2016 06:27 PM
TheManOutside
06-18-2015 03:32 PM
