95 tacoma leaf ?'s
Old 07-03-2009, 07:03 PM
wunbigtacoma's Avatar
95 tacoma leaf ?'s
what is diffrent on the 98 and up leaf's,will they fit 95-97? are they just longer wider,can some one shine some light on this ?
Thanks
Old 07-07-2009, 09:58 PM
zidaro's Avatar
Stock 4x4 '86-'95 minitruck leafs are a straight swap and will give ~2" lift.
'98 leafs will fit in front hangers but you will have to relocate rear hangers for correct shackle angles (leafs are longer than the 95-97s). The axle will have correct placement, extra length is in rear of spring. Lift will correspond with mfg. spec.
Hope that helps a bit.
TTORA is a great source
aaron
Old 07-08-2009, 07:39 AM
scuba's Avatar
Yep, What he said, Buy some mini truck springs..
Old 07-12-2009, 05:57 PM
so it is just the rear shakle's? that would be diff?or could you just buy a shakle kit also to fix that. i was just woundering looks like that would be pretty close,but what do i know,iam going to buy procomp springs for th e rear just curious about the leafs though,and thax for the info.
Old 07-12-2009, 08:00 PM
scuba's Avatar
As quoted from
Originally Posted by AllPro Offroad
Mounting our springs on 95-97 Tacoma's will require new front spring hangers 2" forward (hole to hole) from stock, and the rear shackle hangers moved back 1".
Can also be read here
Old 07-13-2009, 04:02 AM
got ya
Old 07-13-2009, 10:25 PM
scuba's Avatar
Also, To answer that question with a bit more tech :
You might be able to get away with the 98+ springs with some long as hell shackles, But youd have a crappy ass shackle angle and your axle would probably be moved either forward or back, thus creating drivetrain problems and not to mention the tires would be in a bad spot for how the rear fenders are cut in the first place, So some would be in order if you actually wheel the thing..
So my advice just get some springs from an older truck..
Good luck..
Zach_trun
01-22-2020 04:42 PM
G-off
12-29-2015 12:44 PM
Jake28296
09-16-2015 06:10 AM
langry345
09-14-2015 03:36 PM
Quick Reply: 95 tacoma leaf ?'s
