YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-24-2005, 11:13 AM   #1 (permalink)
95 p/u with new 32's please help!!
alright i just put on some 32-11.50x15 mud rovers on 15x8 3.75 bs rock crawlers..now when i put them on they rubbed while backing up so i put 10 turns on the torsion bars,and now they are still rubbing but only on the bolt that holds the mud flap on..is 10 turns too much or too little..any other suggestions would be good..
thanks
yarmish is offline
Sponsored Links
To remove this ad, register today!
Old 09-24-2005, 11:40 AM   #2 (permalink)
mt_goat's Avatar
I'd recommend ball joint spacers over t-bar cranking. You may have to get at least a 1" body lift. You could always remove the mud flap and pound in the spot of rubbing with a BFH too.
__________________
Dale
"America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens
Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx
mt_goat is offline
Old 09-24-2005, 12:11 PM   #3 (permalink)
SolidDigital's Avatar
I'd remove the front mud flaps, my 31's rubbed on the drivers mud flap so I took my front ones off and it looks a lot better.
Got any pics of the new wheels and tires?
__________________
89 Deluxe Short Bed, 3.0 V6
5spd, 4x4, 31x10.5 BFG Radial Long Trails on 15x8 Pacer rims,
K&N air filter, high flow cat, Dynomax 2.5" Super Turbo muffler, Sunpro tach...
Fiamm 125db. low note horn
Pioneer 50w x 4 cd player, Polk speakers
SolidDigital is offline
Old 09-24-2005, 12:41 PM   #4 (permalink)
Silver_Truck's Avatar
Send a message via AIM to Silver_Truck
ya ditch the mud flaps...you should be able to fit those without cranking your bars that much...try lowering em back down a bit a pounding your pinchweld flat
__________________
-Geoff
*1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi.
Silver_Truck is offline
Old 09-24-2005, 09:15 PM   #5 (permalink)
CoedNaked's Avatar
You didn't crank the torsion bars with the wheels on the ground did you?
Did you get an alignment after adjusting your torsion bars?
The mudflaps make these trucks look awesome. I am against ditching the mudflaps. Especially on 89-95 P/U's.
I say go bodylift over any torsion bar adjustment and over ball joint spacers. Because it will keep the truck relatively level. Once you screw with the suspension in the front (IE either adjusting the torsion bars which makes the ride stiffer and sucks up the little articulation you have, or putting ball joint spacers on which I'm not personally partial to) you have to do something with the suspension in the rear either by getting new/higher riding and/or an extra leaf spring, or longer shackles, or ...??
Mind you if you still have the stock leaf springs you might want to opt for replacements by now. My truck received new leaf springs on top of an extra leaf spring last year and the rear rides a lot higher (well, a lot higher compared to most saggy rear leaf springed 89-95 P/U's). I have the torsion bars in the front cranked down to stock height (they were originally cranked up when I got the truck). Let me say the truck rides a lot more level and the trim to top of the rim measurements are just about equal on all 4 wheels - maybe just slightly higher in the rear (around 13 1/4"). I think these trucks look awesome when the wheel well spaces are equal so the truck appears to ride more level. Sagging rear leaf springs kinda look weak on 89-95 P/U's.
My vote do a 2" bodylift and if the rear is sagging put some new leaf springs in the back, and keep your mudflaps on all 4 wheels
__________________
1993 Xtra Cab Pickup | 4x4 | 3.0 - V6 | R150F | Silver-Grey | Amsoil 10w30 synthetic oil | Amsoil Synthetic Drivetrain fluids|
Borla Cat-back Exhaust | OME HD Leaf Springs | Bilstein HD Shocks | Downey Idler Arm Brace | Grey Husky Liners | SR5 Bucket Seat Swap | Color matched Canopy | Yakima racks | Line-X OTR | Michelin LTX A/T 31 x 10.5 x 15 | 319,300 KM's (199,500 miles) | Fish on
CoedNaked is offline
Old 09-24-2005, 10:08 PM   #6 (permalink)
dlbrunner's Avatar
Don't get rid of the mudflaps, but I would advise trimming a few inches off the bottom, I tore mine off on the old pickup while backing up in rocky terrain. The flaps are nice to keep all the crap off the truck.
__________________
Duncan
Current: 95 4X4 SR5 V6, Yakima tracks/rack installed. Aisin hubs. Sonoran Steel IFS Truss. Cobra CB(finally!)
Desired: 66 FJ45 shorty
EX's: 89 4X4 V6 Downey'd
72 FJ40 W 350/SM465 powertrax, "Billy"
dlbrunner is offline
Old 09-24-2005, 11:51 PM   #7 (permalink)
Staff
rocket's Avatar
Quote:
I agree. Looks better IMO.
__________________
under construction: '96-'02
gone: '92
rocket is offline
Old 09-25-2005, 10:06 AM   #8 (permalink)
Send a message via AIM to samcarroll Send a message via MSN to samcarroll
Quote:
I took mine off awhile ago when i got my 33"s and i think it makes it look for rugged. I dont have any form of flaps on mine.
__________________
-Sam Carroll
1990 22RE Pickup
samcarroll is offline
Old 09-25-2005, 01:19 PM   #9 (permalink)
thanks everyone for your replys,i think i am gonna ditch the flaps and bring the t-bars down a few turns and see how it works...also what would i need for the rear about a 1 inch longer shackle than stock?
thanks
yarmish is offline
Old 09-25-2005, 01:36 PM   #10 (permalink)
4Crawler's Avatar
You can do a little inner fender trimming, ball joint spacers, longer rear spring shackle among other things:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
10mpg with 32's nor*cal runner Newbie Tech Section 17 01-22-2007 10:56 PM
Got the 32's on callmej75 86-95 Trucks & 4Runners 58 06-17-2006 09:06 PM
33's or 32's?? sorry I have to ask Magreger Offroad Tech 22 08-19-2005 07:32 PM
32's ??? jdecker 95.5-2004 Tacomas & 96-2002 4Runners 3 10-04-2004 12:10 AM
4.88's and 32's?? WSU4runner 95.5-2004 Tacomas & 96-2002 4Runners 3 03-16-2004 12:13 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
