95 Landcruiser brake problems. Help
Old 07-17-2005, 09:11 PM
coloradosafaris's Avatar
I have a 95 Landcruiser and have just got the thing set up and ready to get out to the dirt. Problem is, I have been having problems getting correct power brake pressure. It has normal power brake feeling on regular driving but on downhill with a bit heavy pressure it is a very stiff pedal and difficult to stop. I did a new master cylinder, full bleed, and just did all the pads but no luck? Any ideas? Please help. Looks like I have found a cool sight.
Old 07-17-2005, 09:20 PM
firemedic's Avatar
Check out www.ih8mud.com 80 series forum for plenty of info, do a search or ask on tht board, it is hands down the best 80 series (what you have) forum. Have you adjusted the LSPV after the lift? If not, do a search on that.
Old 07-17-2005, 09:27 PM
Do you mean the rear bias adjuster? Thanks.
Old 07-17-2005, 09:42 PM
firemedic's Avatar
Yes, Load Sensing Proportioning Valve.
cruisin69
Early Land Cruisers (Build-Up Section)
34
05-22-2018 12:25 PM
Marsheen
02-17-2016 12:29 PM
skoti89
09-11-2015 07:46 AM
bfmcelroy
08-18-2015 06:42 AM
Quick Reply: 95 Landcruiser brake problems. Help
