95 4Runner 6" susepnsion
Old 01-25-2004, 10:33 AM
LT_Z's Avatar
well....I decided not to get the 96 cuz i ran into a way clean 95 with a brand new engine, and it looksl like maybe more stuff is available for the 95. Im looking for a 6" suspension lift whose got the best one ? I want to clear 35's for sure and will probly have to regear. Thanx in adavance for the info !
Old 01-25-2004, 10:34 AM
Fink's Avatar
I would guess BigBadBlue would be one of the guys to talk to...I can't remember exactly what he has but I'm sure he could point you in the right direction.
Fink
Old 01-25-2004, 10:51 AM
Flygtenstein's Avatar
Best 6" suspension lift would be 4" lift springs and 2" drop hangers. Only problem is those things do not just bolt on.
There are a number of ways to get 35's on a 95 runner, some of which are even being discussed in other threads right now.
Old 01-25-2004, 11:08 AM
LT_Z's Avatar
you mean drop shackles ? who is bad blue is he running 35'S ? 4" is tallest bolt on kit huH ? cant seem to find any others
Old 01-25-2004, 11:17 AM
Los Gatos?'s Avatar
Total Chaos Fabrication and EIB both make 6" long travel front suspension setups, which are bolt on. I think you're basically on your own for the rear suspension in terms of getting 6" of lift, I think you'd be looking at maybe a chevy leaf spring swap or custom coils.
Old 01-25-2004, 12:17 PM
doink's Avatar
could do the ol 4 inch bolt kit such as superlift/trailmaster/procomp then the ol 3 inch body
Old 01-25-2004, 01:18 PM
Dude236's Avatar
4" + 3" body would work, but i tend to avoid bodys. i have a 4" procomp and 33s. it sounds like your 2 best options are the total chaos front + many rear options, or the most badass option, a SAS (solid axle swap), this would articulate way better than any ifs kit and the 6" would be pretty easy to get, this would probably be the more costly route. if you want to do the chaos front +rear, you can get a 4" leaf spring and shackle it, which is probably what id do
Old 01-25-2004, 01:26 PM
RedRunner_87's Avatar
You can check out Total Chaos at Kartek . But they only make a 4 inch lift for the 95's. For the rear you can get Deaver leaf springs, you can also check them out at Karteck.
Old 01-25-2004, 01:42 PM
LT_Z's Avatar
What all is needed for the SAS. I think im leaning more that way. The SAS vs. TotalChaos the SAS would have more clearance correct ? When doing the SAS what front end is used ? old toy front or like dana44 or what ? then what leaves steering components etc. Is there any write ups. I pretty sure i could do it myself i just need to figure out whats needed. THanX in advace.
Is there any in here with 95 SAS ?
Peace
Old 01-25-2004, 02:11 PM
OneTrickToy's Avatar
Buy UpInDAir's front axle. He's upgrading to beefier axles. Check out the Classifieds "For Sale" section for his post.
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 95 4Runner 6" susepnsion
