94 XCab 4x4 Rims
94 XCab 4x4 Rims
I have a 94 XCab 4x4 4 cyl. Currently it has 15x6 stock rims on it and I hate the look. Can I go to a 15x8 or a 16x8? I like the black Wheelers and/or I also have a set of rims from a 85 that are rock crawler type wheels that I could put on.
If I go to that size do you think I would have body rub issues, being that the truck is stock?
One more question......Is there anyway to get some lift without a body and or suspension lift?
Thanks in advance.
Thanks in advance.
Yes my man you can raise it a bit with the torsion bars and get an add a leaf for the back, I used to have a 94 and had amer racing wheels 15x8 and 31x10.50 tires and they did rub a little, however mine was a 4x2 with a 6 inch lift, your 4wd is already high and you should be able to turn the torsion bars but the ride will be very stiff.
