94 4Runner with 4'' suspension lift, what kind of spacers?? plz help
Old 03-29-2004, 07:32 PM
victimeiced's Avatar
hey guys, before putting Superlift's 4'' suspension lift on my 4Runner, it sagged pretty bad in the back. And now after the lift it is still sagging. So my plan is to get spacers for the rear and crank the torsion bars a little to gain some more height while doing this. I don't really know much about spacers, can anyone help me out and give me a name or link of what i should be using?? And how many inches can you go with spacers?? I figured i would buy 2-3" rear spacers, then if its too much and the back is higher, crank the t-bars.
Any help/input is really appreciated, cuz as soon as i know what to get i'm gonna do it
Old 03-29-2004, 08:05 PM
Designsbyme's Avatar
I'll be doing this to my truck. I have the pro comp lift though. To take care of the rear, try these. http://www.allprooffroad.com/coilrear.html
The coil spacers.
For the front, I wouldn't crank the torsion, that will make your truck ride crappy. Try these instead. http://home.san.rr.com/sdors/SDORS%20spacer%20page.htm
Good luck!
Old 03-30-2004, 12:34 PM
they only make a 1.5" for the rear on the 90-95's... do ya think that will be enough to correct the sag?
Old 03-30-2004, 12:59 PM
snoozer's Avatar
I think you need to scroll down the All Pro page more. The 1.5" coils at the top will lift your Runner 1.5" over stock. There are 2.25" spacers at the bottom of the page that you could add to your saggy springs. You may be better off getting FJ80 coils for the rear anyway. Do a search for those for more info. Flygtenstein and a few others have those.
Old 03-30-2004, 02:34 PM
blackrunner91's Avatar
hey man, I got the Superlift 4-5" kit. I also still haad the sag in the rear of mine too. I used 2 5/8" spacers to correct the sag. It ended up looking pretty good. post some pics when you finish.
,Louis
Old 03-30-2004, 03:05 PM
anthony1's Avatar
Get rid of the brackets for the links that came with the kit...It's going to bend when you flex.
You can go with Allpro links or run the stock ones. Get the upper links from AllPro so you can tilt the pinion angle.
Old 03-30-2004, 03:38 PM
well i already have the superlift on.
So i guess i'm gonna try those 2.25 spacers and see how they work out for me.
Old 03-30-2004, 03:44 PM
anthony1's Avatar
With 2.25"spacer on, you might have driveline issue. I went to OME680 springs and had to replace my drive shaft with lenghthen front pre86 d-shaft.
Old 03-30-2004, 04:05 PM
Flygtenstein's Avatar
Wait a second.
$150 for new 2.5" rear spacers or $150 for new coils so you don't have to mess with the coils separating from the spacers and wanging around.
The smart money is on the new coils.
Old 03-30-2004, 04:58 PM
I already have the superlift coils on though, and wanted to keep all the superlift components on. And new coils would be 5.5", and i think i'm gonna need more than a 1.5" gain to even the runner out.
Old 03-30-2004, 06:00 PM
yeah, i was gonna buy new OME coils too and do without the spacers, but I got the spacers for $75 compared to the $150 or whatever the coils cost. In the future I do want the coils though. Anyways, yeah, I'm having rear driveline issues too. I installed a Tom Woods custom driveshaft with a dual cv joint in it and it didn't even fix my bad shaking problem. It only shakes at like 10 mph and then at about 65mph. But, I just bought some Downey adjustable upper links that I should have next week to fix the pinion angle problem. Oh, and I was already having the pinion angle problems before I installed the coil spacers.
Old 03-30-2004, 06:52 PM
doink's Avatar
i put the downey spacers on top of mine and they cured my sag with my 4 inch lift. then again, i have a custom rear bumper on the back ..causing it to sag..
Old 03-31-2004, 09:55 AM
Mikronized's Avatar
I figured I should post in here seeing as I've just delt with this same issue... the magic 5.5in coils that allpro sells are OME860's which are too tall to be used with a superlift 4" kit without modification to a bunch of stuff... My runner with a 4" superlift kit sags about 1.5" down in the rear, when I put the 860's on the rear was about 2" higher then the front, which is too much without getting work done to the front, unless you like your rig "stinkbugging" all the time..
If I had stayed with those coils I would have had bad driveline issues, I'd need new rear shocks(the superlift ones aren't long enough), I'd need a new panhard mount(the superlift one isn't long enough)... I could have gotten those front balljoint spacers to even out my runner at about 5.5-6".. but it will be more then $500 for all the parts someone with a superlift kit will need to go from 4" to 6" the right way... unless of course you don't really want to wheel, then just buy some big spacers, crank your bars and live with the super crappy ride/driveline in the gastank.
I decided that untill I have alot of money lying around to buy all the needed parts and a new driveline, to just go with 1.5" spacers on top of my superlift coils... that way I could use my same shocks, no panhard adjustment is needed and your driveline should still be long enough. I bought daystar spacers but the downey spacers Doink has will work too.
Hey blackrunner, how much were those downey upper links? I don't see them listed on the website.
Old 03-31-2004, 10:54 AM
anthony1's Avatar
You don't want those coil unless you SAS your truck.
I did it and those OME860 are great. The truck is leveled with the front. I'm going with 9012 shocks.
Old 03-31-2004, 12:21 PM
Mikronized's Avatar
what did you do to your panhard mount to use those coils?
Old 03-31-2004, 12:47 PM
Mikronized, I got those Downey links from a member on the board here. I haven't got them yet though. They should be here next week. I was looking through the Downey catalog and they are in there for $249, but I got them, a set of 3.25" coils, 1.5 spacers, and 2 new shocks from Downey for like $200. I figured I couldn't beat that with a stick. The coils and shocks are going on my little brother's 2nd gen. when we buy it next week, but the spacers will prob. be for sale.
Old 03-31-2004, 12:58 PM
anthony1's Avatar
here's a pics of what I did.....
http://home.earthlink.net/~audiorat1...s/rearsu~1.jpg
that pic is with stiffer springs ...I got it to come down a bit with OME 860. The rod is pretty much parrallel to the axle now.
I got downey on right side and AllPro on the other.
Old 03-31-2004, 01:20 PM
Mikronized's Avatar
Blackrunner, how'd you get that deal? did you buy that set from someone on the board?
Anthony, thanks... I remember you posting that photo before.
Old 03-31-2004, 01:29 PM
Yeah man, I bought all of that stuff for like $200 plus shipping. I can't remember the guys name on here though.
Old 04-29-2006, 11:40 AM
94runnerguy's Avatar
I think daystar 2.25" spacers are the best. I plan on getting the 4-5.5" superlift, 2.25" daystar spacers, and 26mm t-bars cranked some to even the spacers out.
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
skoti89
07-06-2015 07:45 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 94 4Runner with 4'' suspension lift, what kind of spacers?? plz help
