92 4WD PU Lurches and hesitates??
Old 12-01-2004, 01:27 PM
LAUDERDALE's Avatar
Hi, i am a relatively new Toyota owner. I bought a 92 kingcab 4wd 6 cylinder 5 speed about 6 months ago. She just broke 100, 000 miles I love my truck and will never go back to anything else. The problem I am having is the truck lurches and hesitates. I thought for sure it was the fuel filter so I changed that but it didn't help. Plugs look fine although I haven't done any maintaince on her except change oil. She looks well taken care of. She idles great just sitting there but when I go to take off she starts lurching just like it was a fuel filter problem. She kicks and bucks as i shift through the gears. Once I get her into 4th and am going 55 miles an hour she runs fine except about every 10-15 seconds she gives a lurch or a buck? Is this a TP sensor problem or oxygen sensor? There are not many folks around here that work on Toyotas. Thanks guys!! Dan
Old 12-01-2004, 02:22 PM
Jared Ajlouny's Avatar
Originally Posted by LAUDERDALE
Hi, i am a relatively new Toyota owner. I bought a 92 kingcab 4wd 6 cylinder 5 speed about 6 months ago. She just broke 100, 000 miles I love my truck and will never go back to anything else. The problem I am having is the truck lurches and hesitates. I thought for sure it was the <a href="http://www.serverlogic3.com/lm/rtl3.asp?si=11&k=fuel%20filter" onmouseover="window.status='fuel filter'; return true;" onmouseout="window.status=''; return true;">fuel filter</a> so I changed that but it didn't help. Plugs look fine although I haven't done any maintaince on her except change oil. She looks well taken care of. She idles great just sitting there but when I go to take off she starts lurching just like it was a fuel filter problem. She kicks and bucks as i shift through the gears. Once I get her into 4th and am going 55 miles an hour she runs fine except about every 10-15 seconds she gives a lurch or a buck? Is this a TP sensor problem or <a href="http://www.serverlogic3.com/lm/rtl3.asp?si=11&k=oxygen%20sensor" onmouseover="window.status='oxygen sensor'; return true;" onmouseout="window.status=''; return true;">oxygen sensor</a>? There are not many folks around here that work on Toyotas. Thanks guys!! Dan
sounds like ur clutch...
Old 12-01-2004, 02:42 PM
LAUDERDALE's Avatar
Hi I never thought about that. The clutch is somewhat loose but she still shifts fine. Dan
kawazx636
10-06-2021 03:03 PM
shredder4286
10-01-2015 01:09 PM
tylermx71
09-29-2015 08:49 PM
Cycles
09-29-2015 06:37 AM
skouba
09-14-2015 06:58 AM
Quick Reply: 92 4WD PU Lurches and hesitates??
