91 T case acting up
91 T case acting up
I have a 91 pickup. When the truck is accelerating, not if I am driving and let off the gas, the transfer case sounds like it is trying to bind up. It only does it when the hubs are NOT locked and when it is in 2H. If I lock the hubs are locked or put it in 4H or 4L it stops. I can also climb under the truck and turn the front drive shaft (when the hubs are unlocked of course) and it sounds like two gears are just barely touching. I took the back cover off and all the bearings look and feel pretty good. Anyone that has any clue what it might be I am taking all suggestions.
You don't mention what transfer case you have: RF1A (4 cylinder) or VF1A (6-cylinder) or auto tranny (unsure what the transfer case designation is). I'm really only knowledgeable about the RF1A and your problem doesn't sound like anything that could go wrong with one of those.
I have a 22re so it has to be the rf1a right???
I talked to the 4x4 place here in town and they said it has to be the plastic bushings in the t-case, sound right???
Phantez
09-30-2015 08:24 AM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
