91 horn wire - YotaTech Forums
Go Back   >
91 horn wire
LinkBack Thread Tools Search this Thread
Old 05-23-2005, 04:00 PM   #1
freshman's Avatar
91 horn wire
please help me identify the wires- 2 wires connected to my horn. 1 has blue with white stripe then the other is green with red stripe. Which is hot and which is ground? thanks.
freshman is offline   Reply With Quote
Old 05-23-2005, 06:53 PM   #2
Yoda's Avatar
The Blue/white is fused battery power. The green/red goes to the horn switch (the switch grounds the curcuit)
Yoda is offline   Reply With Quote
Old 05-24-2005, 04:41 PM   #3
freshman's Avatar
thanks! but now that im changing the horn where theres only one lead connection and the body of the horn will be the ground connection when bolted to the truck, how will i wire it so that i can still use the stock horn switch (using the two stock wires)? need your help again...
2001 4Runner 4x4 mussy01 The Classifieds GraveYard 13 12-13-2016 09:20 PM
1uz wiring swap confirmation sanctfy All Other Toyota Swaps 6 09-15-2015 03:52 PM
No blinkers/wipers ghostmoney 86-95 Trucks & 4Runners 7 09-10-2015 03:46 AM
85 Toyota Pickup 4x4 22R Hazard problems jimkoz26 General Electrical & Lighting Related Topics 3 08-05-2015 04:15 PM
Steering Wheel Squeak RBK Newbie Tech Section 5 08-01-2015 02:55 PM
Tags
91horn, fj40, ground, horn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
