906's in rear only
906's in rear only
a friend i work with has the same problem i had with the weak rear springs and bottoming out, i fixed mine with pp's, but he does not want to go that route, is anyone here running 906" in the rear and stock springs in the front, i know it will work but does it look rediculous? i thought about doing pp's in the rear only but with the amount of lift i got that would definatley look akward, thanks in advance , oh yeah it a 98 limited 2wd
Ewe...on a 2wd it might be a bit of rake. He'd probably see 2" out back instead of a 4wd which would probably only see an inch. He could always go economical with a spacer lift upfront if it was too much out back.
I thought about replacing my rear springs with the 906s in conjunction with my air lift 1000. The stock springs are starting to sag even with the airbags.
kirkrunner
07-27-2015 07:59 PM
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
