| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
That emissions part is the Air Suction read valve.
You're supposed to pack the oil pump with petrolium jelly, it primes the pump and dissolves into the oil when it heats up. I have just heavily oiled the components upon reassembly in the past and it has worked fine. You will need to drop the oil pan to clean it out, and you will have to move the front diff. out of the way to do it. Here is the front diff. removal procedure from my 89 factory service manual: Drain dfferential oil. Disconnect propeller shaft (driveshaft). Disconnect driveshafts from side gear shaft. (these are the inboard ends of your front CV shafts, 6 nuts each. If you have the front end jacked up, have a friend push the brake pedal w/hubs locked to get the nuts loose). Disconnect vacuum lines and 4wd indicator switch if you have auto hubs. Remove front diff. mounting bolt and nut. Hold the diff with a jack, then remove left and right rear mounting bolts, lower differential out of truck. I'd recruit an extra set of hands for that step. Installation is the opposite of removal. (duh) Order a steel backed timing guide/chain kit from engnbldr.com so you will never have to clean broken plastic chain guides from the oil pan again. also, don't forget the hidden head bolt at the very front of the head. It is a 12mm and will be hidden in a puddle of oil right under the distributor shaft and threads into the top of the timing cover.
__________________
1987 4-Runner 305,000 miles 1990 Dodge 4x4 Cummins Diesel 2003 VW Jetta Wagon, TDI Last edited by yotafreakshow; 10-16-2004 at 05:45 PM. |
#3 (permalink) |
Thanks for the quick, informative reply!
I found out that the Air Suction Reed Valve (AS Reed Valve) is also known as the PAIR Valve (Pulsed Secondary Air Injection System). It's available from Toyota for just $216.48 + tax! I think I'm going to go to the local Pick-N-Pull to see if I can find one there. I had already purchased and installed the regular guides, so I'll ride with them for now. After winter, maybe I'll redo everything including a new cam, metal backed guides, new header, etc. But for now, I just need to get through the winter.
#4 (permalink) |
I put the regular plastic guides on mine a while ago. Nothing bad has happened yet. I figure they're allright to use; you can't expect everything to last 200k miles.
__________________
Nathan Buchanan 1993 Toyota Pickup |
#5 (permalink) |
In the Haynes manual, before installing the head, it states to "apply sealant to the 2 front corners of the block", where the seam between the block and timing cover meet. What type should I use? I just bought a tube of VersaChem Mega Grey O.E.M. Import Gasket Maker. It says it's a direct cross-reference for Toyota's part numbers:
00295-00102 00295-01281 00295-01208 Will this work, or do I need to get something else? TIA, Jovis |
#6 (permalink) |
Sorry to bump this, but I know someone has the answer to my last question. Anybody?
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's {REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop |
#7 (permalink) | |
Quote:
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
| Tags |
| 22r, 22re, air, block, cylinder, emissions, engine, head, import, pair, plates, removal, secondary, valve, wiki |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine probs/questions with '87 22RE | dgomes | 86-95 Trucks & 4Runners | 3 | 07-03-2007 06:11 AM |
| FS: 89 Toyota Pickup 4x4 22RE engine in Las Vegas, NV | INFIDEL | The Classifieds GraveYard | 1 | 02-06-2007 04:41 PM |
| 90 22re swap into 89 toyota truck questions | YOTAKIMMER | 86-95 Trucks & 4Runners | 10 | 10-24-2006 08:07 AM |
| 22RE cylinder compression/ engine removal and swap questions | the4x4runner | 86-95 Trucks & 4Runners | 6 | 07-25-2006 03:48 PM |
| 22re Engine refresh questions. | psychobillyman | 86-95 Trucks & 4Runners | 6 | 05-31-2006 05:40 PM |
