882 lift+trim packer needed?
Old 03-04-2009, 09:05 AM
jdmaccord6's Avatar
I just put in an order for 882 springs and OME shocks. I was reading that some people had the uneven lift problem? How much of a difference in height would it be side to side? Will i need them? I just want to make sure i have everything for assembly just so i won't have to take the struts out twice...
Old 03-04-2009, 10:18 AM
algranger's Avatar
Are these for a straight axle truck? When i ordered my OME's there was a left and right side front spring. If they are the same, just put some shims on the driver side perch to even it out.
Old 03-04-2009, 11:16 AM
jdmaccord6's Avatar
Oops, it's a 3rd gen 4runner. I think i was reading people are about 1/8th inch to 1/4 inch off?
Old 03-04-2009, 12:25 PM
Ron Helmuth's Avatar
Be sure and verify first but I believe they are designed that way to accomodate the weight of the driver.
Old 03-04-2009, 05:35 PM
emptypockets's Avatar
Mine were dead even, so no need for trim packers on my rig. It's been a while since I installed mine, but I don't remember them being labeled driver or passenger side. Take a measurement before installation and the longer of the two would go on the drivers side to compensate for the weight of the driver and fuel tank.
Old 03-05-2009, 05:26 PM
skjos's Avatar
Before I put on my 881's I had a 3/16" mis-match, after the 881's I still had a 3/16" mismatch (the driver's side was lower).
If you don't have a mismatch with the stock springs, you should be OK without a trim-packer.
This mismatch is not visably noticable, and after driving a year on the springs, my mismatch is down to 2/16".
Old 03-05-2009, 05:36 PM
waskillywabbit's Avatar
Originally Posted by skjos
...my mismatch is down to 2/16".
Is that like 4/32" or 8/64"?
Old 03-05-2009, 05:43 PM
Fink's Avatar
When I did my OME lift on my '99 I put on two sets of top-out spacers - I got them from a former member here.
I used them to even out the lift from front to rear.
I didn't have any problems with it being uneven side-to-side.
Fink
Old 03-06-2009, 05:49 AM
racedirt1's Avatar
Old 03-06-2009, 10:40 AM
skjos's Avatar
I think it's closer to 125/1000
Old 03-06-2009, 11:52 AM
Fink's Avatar
Fink
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
Road Bull
10-10-2015 04:55 PM
TURBOrunnerNM
07-22-2015 11:01 AM
mickyd9990
07-06-2015 09:01 AM
Quick Reply: 882 lift+trim packer needed?
