881 & 890 install which side? ARB label issue fixed =)
Old 09-07-2007, 04:42 PM
skjos's Avatar
I know this issue has been covered before, but I just want to let you know OME has fixed the LH/RH or DS/PS labeling issue. Now they just label the 890's A and B and the 881's 001 and 002.
Because there are no instructions, I'm going to install them per the information the yotatech forums have provided me.
890's - the longer coil goes on the drivers/gas tank side.
881's - these are nearly the same length, but one of them is a couple milimeters longer, I will be installing the slightly longer coil on the drivers side.
Does this sound right to you 881 / 890 vetrans?
Also is there a reason one of the n91sc shocks has yellow busings and the other has black bushings?
Thanks
voiddweller
19
05-02-2016 09:10 PM
Jmiller1023
23
08-06-2015 07:03 PM
Quick Reply: 881 & 890 install which side? ARB label issue fixed =)
