88 7MGTE 4Runner going again, now intercooled and more
Old 03-27-2005, 03:26 PM
GTE4runner's Avatar
I have a few more bugs to get out, but I've been driving it for a few days now and it's great What I've done recently:
3200lb pressure plate, rebuilt R150F trans
I blew the seals out of the slave cylinder after about 150 miles with the 3200lb pressure plate. My toyota dealer buddies hooked me up with a stainless braid piece of flex line to replace the rubber one, as it was stretching too much and limiting the slave cylinder travel. They also gave me a slave cylinder out of a 01 RAV4, which is slightly larger in diameter so it has a little bit less travel than the stock slave but also makes the pedal a little bit lighter.
Upgraded turbo:
intercooler
IC mounts welded in place:
IC pipes painted:
All installed:
Here's what she's looking like right now:
I'll mount the winch solenoid under the hood and then I can raise the bumper up to meet with the grill. For the center section of the grill I'll either modify the stock piece or make something out of mesh.
What do you guys think? It's pushing around 350hp at the wheels right now. Any idea what it's worth? Interior is great, and it has 151k miles.
-Mike
Old 03-27-2005, 03:29 PM
NCSU-4runner's Avatar
why you selling man? This is a nice truck, should bring in good money.
Old 03-27-2005, 03:39 PM
GTE4runner's Avatar
I'm moving to california in two months for a job so the idea of selling it has crossed my mind to avoid the hassles of getting it emissions certified there. I'll probably hold onto it, but I just thought i'd see what people think it's worth for the heck of it.
Glad that you're truck is close to being drivable Jeremy, I'll bet you can't wait.
Old 03-27-2005, 04:57 PM
i'm getting my fuel line fixed tomorrow then i should be able to cruise around a bit.
Old 03-27-2005, 06:27 PM
DudeBud's Avatar
very nice rig what radiator are you running looks like a griffin but whats it for?
Old 03-27-2005, 06:30 PM
GTE4runner's Avatar
Thanks It's a universal griffin, chevy style because of the sides the necks are on. I picked it up at Summit for $180
Old 03-27-2005, 08:35 PM
yea i had a griffin but the damn inlet/outlet were so much bigger i couldnt get them to seal well enough on both the motor and radiator so im running a stock supra radiator for now cost me just as much for a stock cheap POS as it was for the griffin
Old 03-28-2005, 03:03 AM
dragr1's Avatar
Wow, let's see some video of that beast!
Old 03-28-2005, 07:41 AM
89macrunner's Avatar
wati your selling that?...THATS AN AWESOME swap..haha the 7mgte swaps always amuse me...such a power increase...have you upgraded your brakes or supsnesion?
Old 03-28-2005, 07:53 AM
FilthyRich's Avatar
i want to see some video of that thing. 350 hp at the rear wheel That's what I am talking about
Old 03-28-2005, 05:19 PM
GTE4runner's Avatar
I haven't gotten to the brakes or suspension yet, but I plan to do a rear disc conversion, possibly larger fronts, and a rear traction bar. Well I guess I put 26mm torsion bars on, an extra pair of leaf springs, and replaced all of the rubber body mounts and bushings with urethane ones, but more needs to be done
I'll post up some current vids in a while, but here are three from last summer with no intercooler and the stock turbo running 13-14 psi. A friend wanted to see if my 4runner was faster than his buddies new v6 accord, and that's what the first two vids are. The second is a Gtech quarter mile run with a friend driving. I've been too busy to take it off road, but hopefully I can do that soon too and vids will follow
http://www.webpages.uidaho.edu/~simm...S/ACCORD~1.WMV
http://www.webpages.uidaho.edu/~simm...S/ACCORD~2.AVI
http://www.webpages.uidaho.edu/~simm...S/QUARTE~1.AVI
Old 03-28-2005, 07:07 PM
Adam F's Avatar
That's great! When I get a house and a garage I'm going to swap a 7MGTE in my rig.
I just wish Superrunner would make the custom bellhousing. I don't want to use a W56.
Old 03-28-2005, 07:09 PM
how hard is your clutch pedal now??? 3200lbs seems rediculus with stock hydrolics
Old 03-28-2005, 07:48 PM
GTE4runner's Avatar
Yeah, making that bellhousing to retain my R150F was the biggest obstacle in the swap. Superunnerwill get to it soon I'm sure since there is such great interest ( hint, hint )
I think I'm getting used to the clutch now, so it's hard for me to say how much harder it is. I sometimes pump the clutch with my hand when bleeding, and I gave up on that pretty quick with the 3200lb pressure plate, for whatever that's worth
Old 03-28-2005, 08:42 PM
Poopy's Avatar
Looks like your using a 2nd gen DSM BOV there? If so those things leak anything over 12 PSI. Get yourself a 1st gen DSM BOV and crush the top of it slighty and it will hold up to 25 PSI no leaks. Oh yeah, 3200lb PP!!! I've got a 2600lb ACT clutch in my Laser and it dynoed over 400 FWHP and it show's no sign's of slipping after 20K miles of abuse.
Old 03-28-2005, 08:44 PM
i'll for sure be investing in one of Rob's bellhousings. Ive seen a couple R151s come and go recently and i didnt jump on them b/c he hasnt gotten them finished yet
Old 03-28-2005, 09:18 PM
Bumpin' Yota's Avatar
what compressor wheel did you get stuffed in the compressor side and did you get a 10* clip on the hotside?
Old 03-28-2005, 09:50 PM
GTE4runner's Avatar
Hmm that's good info, but I don't know what the valve was original equipment on. It's a Bosch unit.
It's a 60 trim compressor wheel, and theres no clipping on the turbine.
Old 03-28-2005, 10:31 PM
Eric's Avatar
I'd trade you my lifted 90 for that thing! already CA smogged
Old 03-28-2005, 10:38 PM
Poopy's Avatar
Is that the stock compressor housing? I have a 50 trim on my Laser but it uses a T04E Garrett housing with a 3inch inlet, BIG. That thing must be stuffed in there. 60-1 isn't a very good street turbo IMO becuase it requires race gas and a lot of boost before it becomes efficient. That is why I chose the 50 trim because I like pump gas. Assuming this is the same on this engine, we are talking about turbo's though so I would figure it would apply either way.
Quick Reply: 88 7MGTE 4Runner going again, now intercooled and more
