87 22r
there's not really much to do besides from the typical stuff like porting and polishing, bigger valves etc. you can run an offenhauser manifold but there usually isn't a whole lot of benefit unless you're running a weber carb(as the weber will bolt directly to an offy intake, while you need a leaky 2 piece adapter to run it with a stock manifold)
87? did they have carbs that year?
Or do you have a 22re?
Cause Kyle is right if you have carbs, and he knows that stuff!!
But if you have a 22re try these:
http://engnbldr.com/
for head work.
An this for alot more.
http://toyotaperformance.com/
for head work.
buckz6319
08-05-2017 03:50 AM
Toys4parts
09-26-2015 01:56 PM
