| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
by both the switch in the cab and your key?
have you done the standard fuse and bolts check? |
#3 (permalink) |
The wiper unit has a switch in it, as well as the tailgate latches, that won't let the window run if they're not tripped. First, I'd remove the wiper arm again and turn the wiper on and off and let it park. If that isn't it, try pushing hard on the tailgate at each top corner to get the latches to seat tighter. These should do it. Then put the wiper arm back on in the right spot and spray silicone spray on the little parking ramp, and inside the door latches liberally.
The other things that happened to me was the harness that goes into the tailgate behind the bumper on the drivers side took too many rocks and broke a wire. That was fun to find.... Also, too many coffee spills in the switch in the console... and no, carb cleaner is not the same stuff as contact cleaner. And Murphy's law says that when you find this out the hard way it will be winter time and the window will be down so you *will* give the stealer $60 for a new switch. Cheeers, and good luck.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#4 (permalink) |
well the key in the tailgate has never worked, its not connected. i took the wiper off and tried that nothing. umm i looked the switch and its making a connection. the bolt that touches a switch is pushing it down all the way. the fuses are all good. i have the realy out of the truck now but dont know what to look for? maybe the motor is just done for? but it all happened after i took the wiper off that one day?
#5 (permalink) |
There is a control box for the tailgate in the left rear kick panel... under the sliding window... check your power in & out... also there is a safety in the left rear corner of the body, up inside the worthless storage door.. it is to protect the window when the roof is off...
I had to by pass the latch safety in the '87... window would go up (or out) when the tailgate was down after that.. Good luck... |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear Window Problem | freeskier125 | 86-95 Trucks & 4Runners | 1 | 05-09-2007 05:55 PM |
| Rear window problem | swerks | 86-95 Trucks & 4Runners | 5 | 08-31-2006 07:46 PM |
| Am I the first with a rear window problem?? | vmax84 | 86-95 Trucks & 4Runners | 12 | 07-04-2005 11:24 AM |
| Rear window problem | Poopy | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-26-2005 09:47 PM |
| Rear window down problem | emplusten | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-06-2003 09:49 AM |
