84 toy oil pressure 22re
i have a 84 toy truck with a 22re and i was wondering where i can install a new oil pressure switch. i want to use an aftermarket pressure switch and im not sure of the best place to put an oil sending switch. Thanks in advance
You can remove the stock oil press sender under the oil filter or run a "T" there so you can keep the idiot light operational. There's also another port behind the front pass motor mount that you can use.
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
