7th + URD AIC Kit - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-10-2007, 05:59 PM   #26 (permalink)
Quote:
Originally Posted by TrackRunner View Post
Ok, so i'm going the bigger injector route. I'm still debating on the SMT vs FTC option, and I only have one more question
What are your thoughts on URD's AFR sensor calibrator? (http://www.urdusa.com/product_info.p..._id=1230100028) It sounds like they are trying to do the same thing that SS was doing with their ESC1, but does it work any better? or is it just he ESC1 branded with the URD logo? If it is different than the ESC1, and works as advertised, then that would fix the 14.7:1 while in part throttle/low boost situation right?
The URD AFR Sensor Calibrator is very different then the Split Second ESC1.
The URD AFR Sensor Calibrator is for the newer trucks with the new style air/fuel ratio sensor as opposed to the old style O2 sensor. The air/fuel ratio sensor is Denso's version of a wideband sensor. Much more accurate then an O2 sensor. It gives a direct indication of fuel mixture as opposed to an O2 sensor which can only report if the mix is richer or leaner then 14.7:1, but not the exact mixture.
The URD AFR Sensor Calibrator is a mappable unit that uses a true 3 dementional map table like the URD MAF Calibrator or the MAF/Timing Calibrator (FTC1).
It will allow you to alter the fuel mixture in CLOSED LOOP mode and it is very precise and repeatable in its operation. It is best used in combination with a MAF Sensor Calibrator or an additional injector system.
For the 4Runner it is compatable with 1999 Cali and all 2000+ V6 engines.
For the Tacoma, it is compatable with the 2000 Cali and all 2001+ V6 engines.
A complete application guide can be found on the URD site.
Gadget
Gadget is offline
Old 02-10-2007, 06:05 PM   #27 (permalink)
Quote:
Originally Posted by JHRRLD View Post
Make sure you actually have the AFR sensor. Stick your head under you truck and see how many cats you have. I also have a 2000 5vz 4wd 4runner but it has federal emissions (which I didn't realize when I ordered the AFR calibrator) and I can't use. From my understanding: 2 cats= AFR (cali models)1 cat= front and rear O2 sensors (fed models).
Anyways I'll drop ship the AFR calibrator NIB to you for $200. Drop me a PM if you are interested.
The number of cats has nothing to do with what sensor O2 or AFR you have.
Your truck is a 2000 4Runner. Yours has an AFR sensor and not an O2 sensor.
Gadget
Gadget is offline
Old 02-10-2007, 09:51 PM   #28 (permalink)
JHRRLD's Avatar
Send a message via AIM to JHRRLD Send a message via Yahoo to JHRRLD
Gadget
Gadget,
Both sensors on my 4runner (pre and post kitty) have the same plugs, are you sure that I have an AFR sensor? Wouldn't the plugs be different if that were the case? I sure hope your right...
__________________
2000 4WD 4Runner Sport, auto, 5VZ, SC, URD fuel kit, 2.2" pulley, 4" deckplate, Trueflow filter, Airraid mini intake, TRD Exhaust, trans cooler, IPT Valve Body, TrueTrac rear, SS 7.2, 285 75R 16 BFG ATs on PC'd LX450 wheels, JAOS color matched Spoiler, Line-X'd stubbs sliders
07 Kawasaki Brute Force 750i, stock for now
JHRRLD is offline
Old 02-11-2007, 09:18 AM   #29 (permalink)
Gadget,
I just looked through all the books, Toyota, Denso, and some other resources we have here. I will have to admit that you are absolutely correct. There were some 2000 4Runner V6s that still used the old style O2 sensors.
Thanks for squaring me away on this.
Gadget
Gadget is offline
Old 03-26-2007, 12:50 PM   #30 (permalink)
TrackRunner's Avatar
So what is the easiest way to tell if I have 02 sensors or AFR sensors? I haven't looked at them closely before and I'm not sure what would differentiate the two. I have a 2000 4runner that is federal emissions as well, so I would like to make sure I don't put down the money for a box that isn't compatible.. tia
TrackRunner is offline
Old 03-26-2007, 01:28 PM   #31 (permalink)
JHRRLD's Avatar
I would say pop you head under your truck and see if both sensors pre and post cat have the same plugs.
__________________
JHRRLD is offline
Old 03-26-2007, 01:38 PM   #32 (permalink)
Yup, look at the plugs and see how many contacts they have. An AFR Sensor has more contacts than a regular O2 sensor (how many I'm not sure, perhaps as many as 5).
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 03-26-2007, 01:41 PM   #33 (permalink)
thank you for the replies.
Old 03-26-2007, 03:35 PM   #34 (permalink)
alright, I went out at lunchtime to check it out, and here's what I found:
- Both plugs are about the same size, and both have four wires going from the sensor to the plugs.
- The front sensor had this written on it:
Toyota
89465
-35530
Denso 0640
- The back sensor (post cat) had this written on it:
Toyota
89465
-35380
Denso 7911
I'm trying to find them on the web to see if they are different. Looks like two 02 sensors to me.. I hope I'm wrong though..
Old 03-26-2007, 04:02 PM   #35 (permalink)
Sponsoring Member
midiwall's Avatar
It'll depend on which engine you have, if you're manual or auto, and if you have CA emissions. "Federal Emissions" doesn't mean anything. California is the issue...
Denso's lookup:
http://www.densoaftermarket.com/cata...&model=4RUNNER
URD's lookup:
http://www.urdusa.com/product_info.p...s_id=430006000
Note that the part number(s) you read off of the parts don't match anywhere.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 03-26-2007, 04:17 PM   #36 (permalink)
From URD's website:
2000 49 State auto V6; Front = 234-4162
2000 49 State auto V6; Rear = 234-4162
Old 03-26-2007, 04:45 PM   #37 (permalink)
Sponsoring Member
midiwall's Avatar
From URD's website:
'k... but like I said, you need to know if the truck has CA emissions on it.
Did you buy the truck new? and in LA? If so, then it's weird that you have different Denso part numbers front and rear right now.
__________________
~ Mark
midiwall is offline
Old 03-26-2007, 04:49 PM   #38 (permalink)
I just got off the phone with Denso and I definitely have two 02 sensors. So I am one of the ones that can't get the AFR Calibrator.
When I purchased the URD Fuel Upgrade kit, they had an option for 95-98 trucks thats included the built in O2 sensor signal conditioner. I chose 2000 since thats what year my truck is (and this obviously didn't include the 02 signal conditioner built in) Does this mean that the FTC1 will not operate correctly because it thinks I have an AFR sensor, when really I don't? tia
Old 03-26-2007, 04:53 PM   #39 (permalink)
midiwall: Sorry, I posted before I saw that you had replied.
I was under the impression that since my truck only has one cat, that it does not have CA emissions on it. I bought it used, and they had already had it smog tested. I gave my VIN number to the toyota parts department, and they confirmed that I have two 02 sensors.
Old 03-27-2007, 01:43 PM   #40 (permalink)
Just to add to the confusion.. I talked to another Toyota parts department and got one of their technicians on the phone. I gave him my VIN, and he said I have three sensors. Going front to back, he said I have an air fuel sensor, then a front 02 sensor, then the cat, and then the back 02 sensor. I called the first shop again, gave them the VIN, and they also said that I had those three sensors.. Now I'm confused. Is the front air fuel sensor that they speak of not the one that the AFR Calibrator from URD uses to trick the ECU? Or is it a different sensor that has nothing to do with the calibrator...
Old 03-27-2007, 04:22 PM   #41 (permalink)
mt_goat's Avatar
Wow, never heard of that before. Have you looked to see if in fact there are 3? I'll buy a round of beer at the next CO4RJ if you have 3 O2 sensors.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 03-27-2007, 04:30 PM   #42 (permalink)
lol, yeah I haven't had a chance to look. I have a feeling the guys in the parts dept. don't realize that they are listing sensors for CA spec, and non CA spec vehicles. So it looks like three sensors to them, when really they are just listing all the available sensors for that year 4runner.
and as far as that round of beer goes.. I might just have to weld on a random sensor and tell everyone my truck is 'special'
Old 03-27-2007, 05:45 PM   #43 (permalink)
mt_goat's Avatar
Yeah actually I have 3 O2 sensors, here's the 2 in the front:
The extra one is for a A/F ratio gauge BTW.
__________________
~Dale~
mt_goat is offline
Old 03-28-2007, 10:54 AM   #44 (permalink)
hahaha, nice! looks like I will need to be you that round of beer
Old 05-07-2007, 09:51 PM   #45 (permalink)
daytraitors's Avatar
Getting URD 7th inj kit a good idea?
I was originally planning on doing the TRD 7th injector kit b/c I was hoping to do it all myself.
Time. . . job. . .
I'm going to outsource this component to an expert who will also help tune the rig (still looking for that guy). Should I return my TRD 7th injector and buy the URD 7th injector?
Should I get a new pump installed? New injectors?
Do I need new spark plugs if I just installed NGK Iridium plugs?
Is there an ECU that will control timing and fuel without having to remap inputs for the main ECU?
d
daytraitors is offline
Old 05-07-2007, 10:55 PM   #46 (permalink)
FED 2000 Ltd. - can run TRD 7th?
I just read that TRD 7th inj. install note.
Does that mean if I have a FED emissions version (with one cat) that I can't use this kit?
Will this be a valid excuse if I want to return my 7th injector (not installed)?
d
Quote:
Originally Posted by QSVeilside View Post
I believe that's right. I recall reading something about the 7th working with the years that have dual cats.
Ok, did a search on google and found this to be correct. Vehicle applications for the 7th injector as well as the installation manual are found on the link below:
http://www.customtacos.com/tech/index.php?article=170
TrackRunner - Open the acrobat file and make sure you choose the specific part number for your application.
Old 05-08-2007, 06:20 AM   #47 (permalink)
mt_goat's Avatar
Quote:
I would, if you can, or at the very least get this URD upgrade kit:
http://www.urdusa.com/product_info.p...s_id=110000039
And yes, you need the pump upgrade (very important) and cooler plugs. Are you planning to run the stock SC drive pulley?
__________________
~Dale~
mt_goat is offline
Old 05-08-2007, 07:21 AM   #48 (permalink)
Sponsoring Member
midiwall's Avatar
And... you should search around the site. Dale, Brian and I have walked a LOT of people through this process before. Check this thread for possibly one of the more detailed babbles:
http://www.yotatech.com/showthread.php?t=111739
It kinda' starts in the middle of the process, but there are a couple of hijacks in there where we take steps back to the beginning with other folks.
Read. Read. Read.
__________________
~ Mark
midiwall is offline
Old 05-09-2007, 02:51 PM   #49 (permalink)
URD Upgrade
What are the drawback of the URD Fuel Upgrade Kit and the 7th injector?
the benefits are fairly well detailed on the website, but what about some of the problems and limitations?
I read something about people taking out a fuse to reset the ECU for some kind of calibration reason. What's up with that?
I've got a 2000 Ltd (single cat) with NGK iridiums.
d
Old 05-09-2007, 02:55 PM   #50 (permalink)
If I get a bigger fuel pump and use the Free FMU, will that suffice? What will that leave out? Where will I be limited?
d
Tags
35380, 4runner, 7th, 89465, 8946535380, fuel, injector, map, toyota, urd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
7th injector or URD kit Primo 95.5-2004 Tacomas & 96-2002 4Runners 21 06-06-2006 12:00 PM
7th injector kit or urd kit??? J95runner 95.5-2004 Tacomas & 96-2002 4Runners 9 06-15-2004 12:52 PM
7th injector vs. URD kit ibsprocket 95.5-2004 Tacomas & 96-2002 4Runners 13 01-22-2004 09:04 AM
2009 InternetBrands, Inc.
