75w/90 vs 80w/90 in the REAR dif... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-17-2004, 11:20 AM   #1 (permalink)
amorphous's Avatar
Send a message via MSN to amorphous Send a message via Yahoo to amorphous
In trying to find Mobil 1 gear oil around here....no one has it in 80w/90
only 75w/90 -
am I cool to run that in the rear dif? I'm in MO...it DOES get pretty cold here....and I did notice the write-up on BOBSR5's site says 80w/90 in the rear....so??
suggestions?
thanks,
aaron
__________________
98 4runner sr5
33"s and locked with the usual suspects
amorphous is offline
Old 09-17-2004, 11:23 AM   #2 (permalink)
Quote:
only 75w/90 -
suggestions?
thanks,
aaron
I'm running Amsoil 75W-90 in the Front/Rear Diffs, Transfer Case, & Manual Tranny. No problems what so ever. Shifts much smoother in the winter with this Gear Lube.
I'd say do it!!! Best of Luck
Andrew
__________________
96 Runner SR5, 4x4
97 Volvo 850 GLT "Rice Killer"
WatsonMD is offline
Old 09-17-2004, 11:49 AM   #3 (permalink)
payyourtoll's Avatar
only 75w/90 -
suggestions?
thanks,
aaron
I dont think Mobil1 makes 80w/90, but Amsoil sure does. You can find info about it on their site, go here:
http://intershop.amsoil.com/cgi-bin/...0/Catalog/1110
Bob's write-up says he used this Amsoil 80w/90 (AGL-QT), which you can find on the above link for 7.65 / qt
__________________
Rob
payyourtoll is offline
Old 09-17-2004, 11:50 AM   #4 (permalink)
mt_goat's Avatar
only 75w/90 -
suggestions?
thanks,
aaron
I've been using the M1 75w90 for mine, so far no problems.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 09-17-2004, 12:07 PM   #5 (permalink)
nunsa's Avatar
I run the RedLine Heavy Shockproof Oil in my Front & Rear axles and the Redline Mt-90 in my tranny & transfer. Great stuff!
__________________
The Master Toyota Tech,
2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package.
"Expert on the 3.0 Engine!"
Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply
US MARINE*** SEMPER FI
nunsa is offline
Old 09-17-2004, 12:08 PM   #6 (permalink)
splitz's Avatar
Not to hi-jack the thread, but can you just switch to the synthetic stuff w/o a problem? I know in motor oil there are problems sometimes.
Also, how did y'all get those darn fill and drain plugs off? I think they are 24mm, and I've been PB blastin um, but they are not budging.
__________________
94 V6 4X4 PU - currently full of H20
splitz is offline
Old 09-17-2004, 12:11 PM   #7 (permalink)
Quote:
PB Blast the HELL out of them, and when you try to loosen the plug, you need to crack it. So hit the wrench with a hammer, should work. A few of the plugs there is not much room at all to play with, in which case I just politely ask them plugs to remove themselves from thy holes, and they abide
__________________
Rob
Old 09-17-2004, 12:31 PM   #8 (permalink)
kyle_22r's Avatar
i've had to go to my mechanic to have him remove a siezed drain plug from my rear diff. talk about a PITA for me, i wish i had an air chisel at my disposal...
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 09-17-2004, 02:21 PM   #9 (permalink)
mt_goat's Avatar
The last time I changed mine I had to use an impact wrench. I had painted my rear diff and the paint must have like glued the plugs in place. The fill plug got mangled enough I had to replace it. BTW always remove the fill plug first, just in case you can't get it off you'll know before you drain all the gear oil out. The impact wrench made a real mess with the drain plug too, I was trying to just loosen it and then remove it by hand but the damn thing spins so fast it was out in an instant and oil poured all over the garage floor before I could get the drain pan in place.
__________________
~Dale~
mt_goat is offline
Old 09-17-2004, 07:05 PM   #10 (permalink)
splitz's Avatar
Ok, well now I feel better. I was feeling like the govenator says "a girlyman" I tried being nice and asking the plugs to exit the holes, yet they are not listening. I guess it'll be no more Mr. Nice guy and I'll have to break out the Impact wrench and get some replacements just in case!
__________________
splitz is offline
Old 09-18-2004, 02:34 AM   #11 (permalink)
Maddog's Avatar
I changed mine today.
I used Valvoline High performance 80/90 gear oil.
I also put some Nulon addititive in the auto trans as well for the hell of it,& it made quite a differance . I need to get the auto flushed soon as it getting a bit stiff & noisy, but i was amazed how well that stuff works on my tired old transmission.
__________________
Maddog
no 4x4 at this time
Formerly >
1990 Hilux Surf (4runner) ssr ltd 3.0 V6,auto,31"s,140k km's.
Maddog is offline
Old 09-18-2004, 08:52 AM   #12 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
heat the plug up with a torch.... they expand and then you put the torch down to grab the wrench it starts cooling at this time you can shock it off...
jimbo74 is offline
Old 09-18-2004, 09:23 AM   #13 (permalink)
Nolan's Avatar
Quote:
were you able to find your redline locally or did you have to order it online? Just wondering because I have never seen it stocked.
__________________
* 4runner * 2WD 2.7L 5spd * 4.88 Precision Gears * Rear ARB Locker * ARB Compressor * 2.5" front/2" rear CF spacers * 4wd springs * Bilstein shocks * 285/75/16 BFG AT's * 16x8 Ivan Stewart TRD wheels *Gibson exhaust * Yakima roof rack * Rocky Mounts Bike Rack * Yakima Lift Ticket 6 Snowboard Rack * Amsoil Air filter * deckplate mod * Optima 34R Red Top * 15% front Tint * PreRunner Front mud flaps * PIAA 1400 fog lights * '02 4Runner Sport Skidplate & Tube Steps * Husky Floor Liners *
Nolan is offline
Old 09-18-2004, 09:49 AM   #14 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
I'm running 75w/90 Royal Purple in my diffs. I love it!!
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 09-18-2004, 09:55 AM   #15 (permalink)
4Crawler's Avatar
Quote:
Its usually available locally, check Redline's dealer page. I found a local race shop that sells it cheap, especially if you get a case. My local Toyota dealer carries it, too, as do many of the local (non-chain) auto parts stores.
Redline Gear Oil info
Don't pay more than $8/qt. for it either.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-18-2004, 10:04 AM   #16 (permalink)
Nolan's Avatar
I have to drive 50 miles to buy oil here locally.......... i guess I will stick to online.
http://www.redlineoil.com/dealers_re...37&submit.y=10
__________________
Nolan is offline
Old 09-18-2004, 11:29 AM   #17 (permalink)
amorphous's Avatar
locally .... they want 9.89 for redline....where can you get it online...or shall I just go w/ amsoil?
__________________
98 4runner sr5
Old 09-18-2004, 12:06 PM   #18 (permalink)
4Crawler's Avatar
Like I said, look at the page I posted above. It has links to the local dealer pages as well as a couple of on-line sources.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-18-2004, 03:13 PM   #19 (permalink)
nunsa's Avatar
I bought the Redline online at www.summitracing.com , I think it was $8 something, a real good price!
__________________
nunsa is offline
Tags
75w90, 80w90, 850, amsoil, m1, mobil, mt90, redline, replace, tacoma, transmission, valvoline, volvo, vs, vs80w
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
75w-90 vs 80w-90 FilthyRich General Vehicle Related Topics (Non Year Related) 11 01-18-2006 09:10 AM
Puddle of 80W-90 - oh joy!!! HaveBlue 95.5-2004 Tacomas & 96-2002 4Runners 6 03-17-2005 10:24 AM
90 vs 95 rear axle TimmyD 95.5-2004 Tacomas & 96-2002 4Runners 6 10-22-2004 12:03 PM
Can I run w/ 75w-90 in my rear diff? JohnStra 95.5-2004 Tacomas & 96-2002 4Runners 4 04-07-2004 10:27 PM
2009 InternetBrands, Inc.
