73k on my '01 - work to be done?
Old 06-22-2007, 09:58 AM
sabre's Avatar
Tires are about a year/year and a half old. Oil changes pretty regularly. Im thinking I might be looking into brakes soon. What should I do exactly? Just pads or do my rotors need replacing based on mileage? I have zero mechanical ability so I will be paying for any and everything. Unless otherwsie directed to do so, lol. Thanks
Old 06-22-2007, 11:26 AM
Next time you get an oil change have them check your brakes. You are probably fine and would only need new pads on the front if anything.
Old 06-22-2007, 11:30 AM
sabre's Avatar
Son of a.....I posted this thread right after I got BACK from the oil change. Thanks any way. Front pads huh? Ill look into that. Anything else I should worry about at this mileage?
Old 06-22-2007, 12:08 PM
profuse007's Avatar
-drive shaft regreasing.
-replace transmission fluid.
-clean MAF sensor.
-replace differential fluid.
_________________
if you plan do services to your vehicle, then you need to know how to properly put it on jackstands. safety goes first.
brake service is not something you want to tackle first. cehck youtube.com b4 tackling.
Old 08-28-2007, 10:59 AM
sabre's Avatar
-clean MAF sensor.
_________________
Well I am having my tires rotated, brakes inspected and transmission flushed and filled Friday. Im alos going to have them do a physical inspection to let me know if anything else needs to be done.
Old 08-28-2007, 02:14 PM
olharleyman's Avatar
check your owner manual and see if like mine it says at 80,000 go to toyota and get your 02 sensor replaced for free parts and labor. I just want to know if they still have that in there manuals. I tryed to get mine done manual in hand then they came back and said it was a matter I had to take up with Toyota of america and they would not do it with out me paying for it then if oked with toyota of america they would reimburse me.
Old 08-29-2007, 12:55 AM
Adam F's Avatar
Timing belt will be due soon. 60k for 96-98 and 90k for 99-02
Old 08-29-2007, 03:27 AM
mkgarrison5's Avatar
perhaps a coolant flush also. esp if its the original coolant
Old 08-29-2007, 04:11 AM
sabre's Avatar
Next on my list then:
Coolant flush
Differential fluid flush
Timing belt relaced
Ill have to check on the o2 sensor in the manual.
Old 08-29-2007, 06:58 AM
86SR522REEFI's Avatar
Coolant flush
Timing belt relaced
Screw the 02 sensor, wait till it goes bad its way too expensive to care about if its not broken. Start saving for a t belt, it will cost you at least 500 no matter where you go, make sure you do the water pump too dont be cheap. Whenever you get your brakes done make sure they resurface the rotors, it will prolong the life of your pads and rotors and make any squeals go away.
here is where you can find out what to get done at each interval, or just go get a maintenance brochure at toyota from your service advisor.
http://smg.toyotapartsandservice.com/index.php
Last edited by 86SR522REEFI; 08-29-2007 at 07:02 AM. Reason: I cant get the link to show up :(
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: 73k on my '01 - work to be done?
