#6 Spark Plug is stuck
Old 08-18-2005, 07:48 AM
callmej75's Avatar
I can turn it about 1/2 turn then it just don't want to turn anymore. Put anti seize on them and the rest of them come out fine. Don't want to strip out the threads or break the plug off. Any ideas on getting it out?
Old 08-18-2005, 07:51 AM
Silver_Truck's Avatar
maybe run the motor a little bit to get the head warm
Old 08-18-2005, 07:57 AM
JL8Jeff's Avatar
Sounds like it might already be crossthreaded so you might be in for some thread repair. I can't get 5 of my plugs loose easily so I'm leaving them for now since the truck still runs well and gets me to work. When I have another vehicle to use I'll tackle the rest of the plugs and just pray I don't loose any threads in the heads.
Old 08-18-2005, 10:51 AM
sandcrawler's Avatar
take it to the dealer; nominal cost/minimum bother. i always piggyback the #6 plug removal/replacement onto other stuff at the dealer b/c it is such a PITA.
heresy, i know...
Old 08-18-2005, 11:09 AM
callmej75's Avatar
I tried that....still no good. funny thing is the last time I changed my plugs it went in fine. No cross threading issues what so ever.
Old 08-18-2005, 01:17 PM
next time when u put ur plugs in put a little bit of motor oil on the threads makes it easier to get em in and out. I dunno I've had 6 be tough to get out too but I just wrenched it out with the motor warm, may not be a good idea tho if there is an actual prob with the threads.
Old 08-18-2005, 02:06 PM
Churnd's Avatar
I always use finger-threading as much as possible. Put the socket and extension on the plug, then thread it in with your fingers. Only foolproof way to know whether or not you're cross-threading. Use the ratchet to tighted/loosen, then finger-thread the rest of it.
But, since it's already probably cross-threaded, I'd take it somewhere to get it fixed. Take it from me... it's NO FUN trying to fix something like that yourself... especially on the 3.0. The only fully safe way to do it for someone inexperienced is to take the head off.
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
Alex Bessinger
08-31-2015 09:17 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: #6 Spark Plug is stuck
