6 cyl missfire (a little long)
Hey guys, I was hoping some of you guys might be able to help. I have a 97 4 runner with the 3.4L just 2wd with 81K miles. I recently got a missfire in cyl 6 code with everything that comes along with it.
I pulled the coils/plugs today and noticed that the top of cyl 2 plug has 2 burn marks where the lead in the coil touches the plug. In cyl 6 which shares the same coil, has a brown build up on the non firing end of the plug, around the seal spot and on the white part of plug (excuse my lack of technical terms).
I want to assume its the coil itself thats cause this problem, but wouldn't I be getting a misfire in 2 cylinders instead of just the one?
A bit of stupidity could have caused this as I drove through a lot of pretty deep puddles (3 to 8 inches deep) while we had a lot of rain last weekend. It didn't start misfiring until about 4 days later. The other day when I started it up and went to work it ran fine, no misfire at all, then at lunch that same day it started missing again.
Any advice? Thoughts?
Take care,
Branden
Take care,
Branden
mr_manny
07-31-2015 10:39 AM
