5vz fe flamethrower injectors
Recently installed flamethrower injectors. Wondering how the system deals with the fact that the air inlet the factory injectors use I seem to have a vacuum leak. So I smoke tested and sure enough smoke around every injector.
Only way I found to plug those leaks is to either pull the manifold off and have the holes welded shut or to stuff as many orings as you can cram in there, then clamp it down. Hopefully sealing the leak.
Could use RTV but it would make a mess and be hard to deal with later. Also possible it could get sucked into the engine, same for JB weld.
LCE_Performance
10-01-2015 01:03 PM
