5VZ 3.4L AC idler pulley
Old Jan 3, 2010 | 02:05 PM
raydouble's Avatar
I'm looking for the bearing number for the AC idler pulley.
If you've replaced yours and have your old one laying around, or if you have replaced the bearing in yours, please, I'd love to know the bearing number for it.... thanks.
Old Jan 3, 2010 | 03:01 PM
Yukon's Avatar
Actually.... I have a like new pulley, and the old one siting in my glove box, ill be home tomorrow night, and can get you the number, otherwise, ill sell it to you?
Old Jan 3, 2010 | 03:08 PM
raydouble's Avatar
Don't even know if I need it yet....that is extremely generous, but really, if you could get the part number off the bearing, that would be awesome.
Heard a squeek on start up yesterday, timing belt, water pump and all accessory belts new.....just thought it was the most likely culprit.
Old Jan 3, 2010 | 04:44 PM
TheDurk's Avatar
New does not mean tight, however. I swapped all mine when I did the TB this spring, and I thought I had them good and tight. My alt belt needed some more turns after a few weeks to cure a squeak. Don't assume your belts are tight until you check. They should all be checked after running-in after replacement. (not TB, of course)
Old Jan 3, 2010 | 06:25 PM
raydouble's Avatar
The guy who did my work was a 25 + year MDT, who has done hundred of timing belt changes on the 3.4L.......that being said...... I checked the belts.
Old Jan 5, 2010 | 01:08 PM
Yukon's Avatar
I see a few numbers. on the inner metal part
6203/12.203
one the dust cover 6203lu
looks like itd be way easier to just buy a new one.
Old Jan 5, 2010 | 01:17 PM
MSR's Avatar
MSR
ask local parts house for a double sealed 203 bearing
Old Jan 5, 2010 | 01:20 PM
raydouble's Avatar
Rebuild procedure here...
http://www.ttora.com/forum/showthread.php?t=138131
There are apparently two different options.
One is OEM and the other is dealer option A/C. Sorry, don't know which is which.
The above procedure should be similar for both.
6203LU =
12mm thick
17mm bore
40mm outside diameter
6301-2RS=
12mm thick
12mm bore
37mm outside diameter
Old Jan 5, 2010 | 04:12 PM
Yukon's Avatar
Hmm thats odd, I THINK this is the pulley i got from advance auto. AC is factory, this is a 99 limited. Those numbers are off the same pulley. Mine doesn't look like the one in that link. bearing pressed in, no snap ring. same as the one i took off the truck
Tell ya what, ill send it to you for the cost of shipping if you want, it was on the truck about a month or two until I got the whole tensioner system from toyota due to me breaking part of it being dumb.
ladybugRC
458
Aug 21, 2020 10:41 AM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
LCE_Performance
Oct 1, 2015 01:03 PM
EVars
Sep 29, 2015 02:06 PM
