5th Gen rims on 3rd Gen
Old 07-27-2010, 11:47 AM
98SR54RUNNER's Avatar
I'm getting my lift on this weekend. I stumbled across a Craigslist ad with a guy selling a set of 17" rims off a 5th generation 4runner.
Anyone seen a third gen with 5th gen rims? Would these even fit?
I'm going to get new tires in the near future and I could get these for probably $300. I think they look pretty slick, I'd just like to hear what YT has to say about it first.
Old 07-27-2010, 12:04 PM
scuba's Avatar
17X8 OEM wheels ?!?!
Buy them before I do.
Old 07-27-2010, 12:14 PM
I know, they look really clean. I like em alot. My wallet is burning after the lift and some other costs, but I want em! One of my buddies got a job with Michelin about 3 months ago and can get me 30% off any Michelin or BF Goodrich tires. I don't think I'll be able to resist on a set this cheap.
So these would fit without problems?
Should I just try to find a crap 17 x 8 rim for a full-size spare?
I like having a full-size spare, so I guess that's what I'd need to do... Just like to get the peace of mind of having the Okay from the YT pros.
Old 07-27-2010, 12:56 PM
scuba's Avatar
The 6X5.5 should fit your 4Runner just fine. It's the backspacing I'd be scurred of. Ask the seller to measure backspacing for you. Stock backspacing on your 4Runner is 4.625 or right about there. The BS on those rims could be 4.5-5"..
Though, if your putting a 11-12.5" wide tire you want 4-4.25" BS to clear the UCA's.
Old 07-27-2010, 02:12 PM
rockota's Avatar
the bs on those rims could be 4.5-5"..
~5.5"
Old 07-27-2010, 02:28 PM
scuba's Avatar
Originally Posted by rockota
~5.5"
Where did you get that info?
And if thats correct.. OP, you'll need at least 1" wheel spacers to keep the rims and tires out of the UCA's.
Old 07-27-2010, 02:32 PM
Elton's Avatar
lol u do realize that box is what the new wheels he got came in
Old 07-27-2010, 09:40 PM
rideexileex's Avatar
i was just about to say... the graphic picture does not match the wheel
Old 07-28-2010, 05:08 AM
clydehatchet's Avatar
ive seen those wheels on a 3rd gen. looks awesome. make sure you have the backspacing and offset worked out or you will need wheel spacers. also, paint em black.
Old 07-28-2010, 10:00 AM
I assumed that the new wheels were the same measurements as the OEM. Still trying to get the backspacing measurement from the seller. I think he'd go to $250 too, so I might be getting these. You never know with Craigslist though until you've got something in hand.
At this price, I'll probably just get them and figure out if they will really fit later. The guy is trying to sell them fast. I figure the worst case is I'd relist and sell them to someone else. I highly doubt I'd lose money at $250-300 for the set.
Old 07-28-2010, 11:12 AM
Gerdo's Avatar
Good looking wheel but if you do go wheeling a 16" wheel is better.
The taller the wheel the shorter the sidewall. The shorter the sidewall the easier it is to pop a bead at lower air pressure so you will have to run a higher psi when wheeling. The shorter the sidewall the stiffer the ride with full pressure or aired down. The shorter the sidewall the less the tire will conform to rocks when wheeling.
Old 07-29-2010, 10:30 AM
rockota's Avatar
Q
Quick Bing search - think it was on Tundra Solutions.
And...
From trying to put '08 Tacoma wheels on my 06 Tundra... About 1" deeper backspacing than the stock 17" wheels.
Old 07-29-2010, 11:45 AM
scuba's Avatar
And...
Well an 08 Tacoma is nothing like a 10 4Runner. Just saying.
Old 07-29-2010, 03:05 PM
LINY4Runner's Avatar
Although I wheel pretty damn hard on a 17 inch aluminum wheel, I would have to agree...if you're a real wheeler, go with a 15" steel wheel, but a 16 or 17 inch alloy is good for a mall crawler who sees trails on the weekend...
but like I said, I wheel the balls out of my truck on the 17's and haven't lost a bead
Old 07-30-2010, 08:55 AM
rockota's Avatar
IIRC, the front suspension is virtually identical. But... I think you are correct. Doing some more digging, it looks like the factory 2010 SR5 wheels are 17x7.5 w/ 4.5" backspacing.
http://www.toyota-4runner.org/5th-ge...-wheels-2.html
Old 07-30-2010, 10:10 AM
scuba's Avatar
I actually do not know if the front suspension is a carry over of the previous gen. Something I'll have to figure out when I see one in person.
Old 09-02-2010, 09:24 PM
DesertDune's Avatar
Did you ever get these wheels? How about a pic? BTW, those wheels are 17x7.5 with 15mm offset. This equals a 4.84" backspacing, approximately. This is the same size wheel as the 17" Sequoia / Tundra split 5-spoke. Many here have put the Sequoia wheels on their 3rd gens with no problems, even stock. Just choose your tire size carefully so that you won't have any rubbing issues.
Also, the stock 3rd gen alloy wheel is 16x7 with 15mm offset. Scuba already posted the backspacing, ~4.6".
The real question is, does anyone have a pic of the 5th gen 20" Limited wheel on a 3rd gen?
Old 09-03-2010, 10:47 AM
mk3supraman's Avatar
Buy them and post pics soon, I'm thinking about doing the same thing
Old 09-05-2010, 06:04 PM
DesertDune's Avatar
There's a guy over on T4R.org with these wheels:
http://www.toyota-4runner.org/3rd-ge...ew-look-2.html
suppra87
07-15-2021 05:15 PM
1uzRunner
63
11-10-2018 03:58 PM
Swampwalker
10-12-2015 09:49 AM
runnermedic
13
09-21-2015 05:20 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: 5th Gen rims on 3rd Gen
