4x4 problems Front diff actuator??
I have an 01 tacoma V6 automatic and I hit the button to engage 4 wheel drive and I get 2 sometimes 3 wheel drive it seems, Binding when I make hard turns. I hit the button to go out of 4 wheel and my light flashes at me. After driving around for about a month annoyed trying to figure out what was wrong I got hands on. So on level ground truck in neutral and transfer case in neutral I removed the bolts from the actuator on the transfer case and popped it out of the gear it was stuck on. Well it got my truck back into 2 wheel drive, so I decided to try my 4x4 again, no solution same problem, so back in the driveway to pop the actuator out of gear again. I have been driving around like this now for several months. I am puzzled, a handfull of other 01-04 tacomas are having the front diff actuator go out on them. Could I have done any damage by popping the rear diff actuator out of gear? And if my problem is in the front actuator why would popping the actuator out on the t-case help?
Thanks in advance for any input!
Well when it was stuck, It pulled real hard to the right most the time, every now and then it would track straight. I could tell that my right front was engaged and so could the smog guy when I took it in he couldn't run it on the dyno.
I have a 95.5 Tacoma. I removed the actuator and slid the sleeve over by hand. My driveshaft turns, but neither of my cv axles turn... what's going on?
I have no 4 wheel drive and getting very annoyed:-(
06-01-2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
