4x4 problem
Old 03-01-2011, 11:01 AM
yankeegrl23666's Avatar
4x4 problem
I own a 1995 Tacoma sr5 4x4. V6eng. and auto trans. IN 2 wheel drive there are no problems, but in 4 wheel high or low, the rear axle locks and then frees up, causing a skipping motion? What could be the problem, and what will it take to fix it?
Old 03-01-2011, 11:06 AM
scuba's Avatar
Sounds like the gear ratios are different in the front and rear diffs. Google search how to check gear ratios.
Old 03-01-2011, 11:12 AM
The four wheel drive was fine though, until cold weather set in. it worked all summer in the mud, and the first time i tried to use it in the the snow, thats what happened. Does this mean the gears are not lining up properly?
Old 03-01-2011, 11:33 AM
justin_4runner's Avatar
sounds like u have a problem in the front diff or transfer case. jack the truck up put in 4wd and see if it still does it , if so then look under as the tires are turning and see where it looks like its binding,
Old 03-01-2011, 05:44 PM
kharris's Avatar
Cool
i told you the same thing three weeks ago looks like you should listen 2 your big brother more often.
gary4runner
09-24-2015 12:53 AM
09-04-2015 09:27 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
garagespace
07-09-2015 08:37 AM
Quick Reply: 4x4 problem
