4wd vsv location
Old 02-06-2009, 09:04 AM
typhoon55's Avatar
4wd vsv location
where is the 4wd vsv location for a 2004 taco? I have checked archives but only info is for earlier years.
Old 02-06-2009, 10:38 AM
Staff
DeathCougar's Avatar
2004 Tacoma doesn't have a VSV. The 2004 tacoma uses an electronic actuator.
Old 02-06-2009, 11:46 AM
typhoon55's Avatar
thx - i guess that explains why i could not find it!
something is tempermental in the 4wd as it seems to work great sometimes but then will not work. I have read that the 4wd should be used monthly just to keep actuator lubricated - I have not been doing that
Old 02-06-2009, 05:00 PM
Adam F's Avatar
Not using it is not likely the problem. Especially on a newer truck. Toyotas are built better than that.
What do you mean by tempermental? Explain in detail please.
Old 02-06-2009, 07:57 PM
typhoon55's Avatar
tempermental as it works great from one day to the next then will not work at all.
it seems to just work when it wants to. Maybe a bad or dirty connector ?
Is there any reported problems with the electronic actuators ?
Old 02-07-2009, 07:31 AM
Adam F's Avatar
no. does the light in the dash turn off? flash? stay on?
Old 02-07-2009, 08:48 AM
typhoon55's Avatar
light in dash works as designed - no flashing - it stays on when 4wd is working - turns off when shifting out of 4wd.
it is the stick 4wd - not the button
Old 02-10-2009, 05:59 AM
typhoon55's Avatar
it works when it wants to. could it be a relay, switch that is intermittent? i would not think so- it seems thay would be working or not.
Old 02-11-2009, 09:59 AM
typhoon55's Avatar
does the 2004 have a front differential sensor as I see it discussed in another thread regarding 4wd issues?
DeathCougar
04-01-2018 11:29 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Sarcazmo
08-15-2015 08:22 PM
Colington
08-13-2015 02:21 PM
genuinegemini
08-03-2015 04:56 PM
Quick Reply: 4wd vsv location
