4WD Transfer Case Actuator - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-16-2007, 04:32 AM   #1 (permalink)
I have a '99 Limited. The other day I pushed the 4WD button on the transfer case lever which puts the vehicle into 4WD "open" mode. Everything worked fine until I pushed the button to put it back into 2WD. It would not go back into 2WD.
I went to the dealer and here's what happened. The service writer said the acutator is broken. It's a $900 part and requires 13 hours of labor because it requires removing the transfer case etc. Bottom line: $2,300 for the fix.
I asked the mechanic if he could get it back into 2WD for me. The mechanic said, no problem. He switched the two vacuum lines located in the engine compartment above the drivers side wheel well. OK, so now it's back in 2WD, but the dash light still flashes.
Question: if switching the two vacuum lines put the vehicle back into 2 WD, then is the transfer case actuator really the problem?
Potomacduck is offline
Old 02-16-2007, 11:27 AM   #2 (permalink)
GSGALLANT's Avatar
What he did by switching your vacuum lines was retract the ADD sleeve in your front diff. Your front driveshaft is likely still turning with your engine if the problem is in the transfer case. Get someone to look under the truck as you drive it slowly to see if your front driveshaft is turning. If you do get the transfer case fixed, don't forget to swap those vacuum lines again to get it to work correctly.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 02-20-2007, 04:13 AM   #3 (permalink)
Anyone else?
Old 02-20-2007, 07:32 AM   #4 (permalink)
GSGALLANT's Avatar
So... did you check your driveshaft or not?
__________________
Old 02-20-2007, 09:53 AM   #5 (permalink)
Yes, the front propeller shaft is turning. The problem is the actuator which is external to the transfer case, but it is pinned inside the transfer case, so it's big job to install a new acutator.
Old 02-20-2007, 09:54 AM   #6 (permalink)
terryjmatthew's Avatar
I am having a similar problem with my 2001. I am going to get a used case for cheaper than the actuator itself.
__________________
-Matthew
http://www.yotatech.com/f79/terryjma...rofile-103826/
TLCA # 17870
terryjmatthew is offline
Old 09-25-2007, 06:25 AM   #7 (permalink)
Haveing the same exact problem with my 99 Limited.....what did you end up doing? I have been driving around with flashing lights and a disengaged ADD sleeve.
__________________
99 Limited 4runner Dark Green
Deckplate Mod
Dr Z ISR Mod
Amsoil Filter
Catch-All Floor Mats
vtruong1 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Need Some Advise on Transfer Case and Actuator vtruong1 95.5-2004 Tacomas & 96-2002 4Runners 1 11-14-2006 04:57 PM
4WD Actuator 3rd Gen. Potomacduck 95.5-2004 Tacomas & 96-2002 4Runners 4 09-29-2006 09:28 AM
Is this the actuator for 4WD? (my 4WD won't engage) cackalak han 95.5-2004 Tacomas & 96-2002 4Runners 9 07-31-2006 10:50 AM
Dexron in manual transfer case and 4wd shifting problems? runethechamp 95.5-2004 Tacomas & 96-2002 4Runners 11 10-19-2005 09:27 PM
transfer case shifter won't shift - '91 4WD Pickup wallaceb 95.5-2004 Tacomas & 96-2002 4Runners 2 01-30-2005 05:26 AM
2009 InternetBrands, Inc.
