4WD transfer box actuator replace problem 4R 96
Hi all,
I bought 4R Limited 96 5VZ-FE. Im unable to set it to 4WD - after pressing the button control start flashes and nothing happend. When I try switches and limitis after post: YOTA 4WD it happens that Actuator in transfer case is faulty (some teths on plastic gear are broken). I found this actuator in shop Toyotaparts : http://www.toyotapart.com/41400-34020.html Will it fit to the transfer box??? or is it different one - i cannot find it in drawings.
Regs mac.
Regs mac.
What you need is more like 36410‑35060
Check toyodiy.com and look up your vehicle for the right part. For my truck the transfer box parts diagram is here: http://www.toyodiy.com/parts/p_G_200...MSTQ_3611.html
thanks already solved in post: https://www.yotatech.com/forums/f2/4...l#post51849864 -
I had VIN problem - number showed SR5 version while it was LIMITED
GreenLion
06-07-2021 10:49 AM
stagger_lee
03-29-2016 06:27 PM
