4WD relay location
Old 12-17-2008, 11:28 AM
Phat Ham's Avatar
4WD relay location
My 4wd isn't engaging and I don't hear the relay click when I pull the lever into 4hi. I have a '96 manual transmission. No push button 4wd. The relay is somewhere on the passenger side right? Do I get to it from underneath the glove box? Do I have to remove the glove box?
Also, while we're on the subject, could it be a bad 4WD switch on the transfer case lever that's causing this? If so, do I get to that switch from underneath or do I go through the top via the center console?
Old 12-17-2008, 11:47 AM
crolison's Avatar
If its the tcase switch your probably gonna have to tackle the problem from the top and bottom.
Taking the center console and shifter plate takes like 5 minutes to do... and isn't hard.
Old 12-17-2008, 08:31 PM
Phat Ham's Avatar
I had to go through the top to get to the o2 sensor harness so I'm familiar with it. I was almost hoping to hear you go through the top so I wouldn't have to crawl under the 4runner.
Nobody knows about the relay location? Guess I'll just have fish around down there and hope I don't yank the wrong thing.
Old 12-18-2008, 08:46 AM
pray4surf's Avatar
You might look behind the passenger side kick-panel fwd of the door... at least that is where the relay is located in my 98 Tacoma...
Kind of a bear to remove that panel..... Remove the plastic sill cover then pull the kick panel towards the back of the truck..
okamikai
04-30-2018 10:19 PM
DeathCougar
04-01-2018 11:29 PM
mussy01
12-13-2016 08:20 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
coryc85
09-09-2015 06:24 AM
Quick Reply: 4WD relay location
