4wd problems... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-06-2004, 02:32 PM   #1 (permalink)
Send a message via AIM to ksig4runner
Unhappy 4wd problems...
Last time i went out, my front differential would not engage and i have no front wheel drive at all. The 4wd selector shifts fine but i have no light go on and nothing seems to be engaging.Is this a problem that anyone has had??
__________________
'93 4Runner SR5 V6 3.0 4x4
31 inch bfg at's, K&N drop in, Eclipse deck, Pioneer speakers, Clifford alarm, flowmaster 40 series
Comin' soon: new shocks, Pre runner light bar, 2 off road lights, yakima rack
ksig4runner is offline
Old 07-06-2004, 02:41 PM   #2 (permalink)
I'm guessing you have the ADD system, not manual locking hubs right? My 93 which had ADD, also had the 4wd light problem. It would flicker after using 4wd for a while or just not turn on at all, which caused the front diff not to engage. I ended up converting to manual hubs and defeating the ADD system(writeup here: http://www.4x4wire.com/toyota/tech/add/). The light would still act up, but at least my 4wd would work reliably now. I never found out what the problem was and still did it after all the vacuum components were removed, but guessing it was the switch in the front diff.
VolcomTacoma is offline
Old 07-06-2004, 02:44 PM   #3 (permalink)
Quote:
My guess is you have a leak in the vacuum line that leads to your ADD system... It's pretty common even though I have never actually had this problem... You could try looking at the lines and see if they are in one piece.
http://www.off-road.com/toyota/tech/add/index.htm should help with checking the system out.
The little green 4WD light not turning on means the ADD is not engaging, most likely a vacuum malfunction.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 07-06-2004, 05:16 PM   #4 (permalink)
rpeAMP's Avatar
Send a message via ICQ to rpeAMP Send a message via AIM to rpeAMP Send a message via Yahoo to rpeAMP
Also try driving for several minutes in 4Hi. When I first bought my 4Runner, the 4WD virtually hadn't ever been used, so it took about 5 miles to get it the light to stop flickering and for it to engage firmly.
__________________
Preston Edwards
1992 4Runner SR5 V6 4WD (5 Spd.)
246,000 miles & counting
2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS
2008 Toyota 4Runner Limted 4X4
15,000 miles & counting
rpeAMP is offline
Old 07-06-2004, 05:18 PM   #5 (permalink)
tombothetominator's Avatar
i 2nd the vaccum check!
__________________
Dont take life seriously, you'll never get out alive.
For those without money or dignity; just add a coke can to the back and call it a race car.
'91 Runner, V6, SR5, 5-speed
tombothetominator is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4WD/ possible T-case problems? Zenkai Newbie Tech Section 4 04-01-2006 09:10 AM
4WD Problems az4x4runner 86-95 Trucks & 4Runners 8 01-20-2006 08:02 AM
4wd problems..... AznSky 95.5-2004 Tacomas & 96-2002 4Runners 15 02-21-2005 06:59 PM
4wd problems dropcivic 95.5-2004 Tacomas & 96-2002 4Runners 7 11-04-2003 07:48 PM
4WD Problems dlotoy4runner 95.5-2004 Tacomas & 96-2002 4Runners 7 07-03-2002 04:42 AM
2009 InternetBrands, Inc.
