4wd not working
4wd not working
Well, took my old 87 out for a spin around my block today (still needs alot of work, but it's up and running). Decided to test the 4wd system out since it hasn't been used in at least a year. We parked the truck facing a curb, put it in 4HI, locked the hubs, and......nothing. The front tires won't turn at all.....my friend had to give it almost full throttle just so it would climb the freakin curb.
I'm completley and utterly new to the 4wd world, so if I'm missing something or did something wrong please.....feel free to correct me. Or if it sounds like a problem, any advice would be great. Thanks!
edit: I guess I should add that the front driveshaft does spin when in gear.
Your truck has a solid axle swapped in? Any sort of locker, limited slip, etc.? I don't know much about sa swaps, but maybe there is a problem with the differential. Try jacking up the front axle, locking the hubs, and spinning the tires by hand. See if the opposite tire and/or front driveshaft spins.
were the rear tires spinning? if so i bet one of your hubs is stuck/assembled incorrectly. if you want i can go pull my dials off the runner and take some pics of what they should look like locked and unlocked....
I was perpendicular to the curb while trying to climb it so I couldn't tell if my rear tires were spinning or not. I put it in 4HI while driving down the street (with the hubs unlocked) and the front driveshaft was rotating.
Tonight my I'm going to jack it up and see if the front ones spin in 4wd, just to be sure.
Originally Posted by 89_4runner
Your truck has a solid axle swapped in? Any sort of locker, limited slip, etc.? .
Could be the differential, but a lot less likely.
This article from off-road.com might help out also with the hubs...
http://www.off-road.com/toyota/tech/aisin/index.htm
Originally Posted by Pretacopower
If you can, I'd REALLY appreciate it.
ashersullivan88yota
01-18-2022 05:37 PM
Road Bull
10-10-2015 04:55 PM
Suprarossa
07-06-2015 05:21 AM
