4wd light not working correctly... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-01-2003, 11:05 PM   #1 (permalink)
My 4wd light will flicker then turn off after in 4wd for a little while. The light flickers when hitting bumps then turns off. After my ADD system was defeated it still does this, but the 4wd works. It seems like after the gear oil heats up it doesn't work. Could it be the switch in the front diff?
VolcomTacoma is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
4WD indicator light not working Igor YU 95.5-2004 Tacomas & 96-2002 4Runners 2 10-09-2006 10:24 AM
Excalibur alarm not working correctly Lanman Alarm Systems 0 12-29-2005 07:37 PM
ABS/VSC Working Correctly? AndroT100 95.5-2004 Tacomas & 96-2002 4Runners 1 01-03-2004 09:43 PM
4wd relay clicks and no light on dash...4wd engaged or not? surferfrank 95.5-2004 Tacomas & 96-2002 4Runners 7 09-15-2003 12:26 PM
2009 InternetBrands, Inc.
