4wd Issues - Delay in engaging
Old 02-05-2015, 07:43 AM
davv1215's Avatar
When I shift into 4wd Hi (whether stopped or under 55mph), it does not engage into 4wd right away. The light does not turn on and I can feel that it is not engaged. However, after driving another few minutes it'll engage. Also, if I park and turn off the car before the 4wd engages and leave it in 4wd Hi, when I turn on the car minutes later, it'll be engaged (I can feel the traction and the light turns on). Any ideas?
98 4runner Sr5 3.4L
Old 02-06-2015, 01:25 AM
wyoming9's Avatar
Red face
The only thing I can think of it is just slow from not being used.
Dirt moisture who can say.
I shift mine in a maybe twice a month of course more in the winter.
If it is cold where you are the cold makes things move slower if they seldom get used
Old 02-09-2015, 07:22 AM
davv1215's Avatar
Thanks for the response. When it's engaged it works fine. The fact that it takes a while to engage (sometimes 5-10 min driving or turning off the car for 5 min then turning back on) isn't indicative of a major issue?
Old 02-10-2015, 02:56 AM
wyoming9's Avatar
Red face
Not yet but it could become one!!
Quite a few different places it could be like I said could just be dirt or something on the verge of failure.
You really don`t want to have it fail at the worst time.
Get a copy of the FSM and figure out just how it works figure out the problem area.
Old 02-10-2015, 07:57 AM
WallyWest's Avatar
The light doesn't come on at all? Mine blinks while it's trying to engage. Usually doesn't work if driving at normal speeds, despite what the owners manual says. I stop, press the button, and then slowly roll forward and it engages right away.
I would think if you get no lights at all when pushing the button that something is definitely wrong.
Old 03-03-2015, 11:20 AM
davv1215's Avatar
Mine is not push button. It's a very delayed in engaging. The light stays off even though I shifted it into 4wd. I know it's not engaged because surfaces I can get out with the 4wd engaged, the rear wheels are just spinning. I'll turn the car off and turn it on after 5 min, and the light will be on and I'll get out of the spot with no problem. The other day it was snowing most of the day so I kept the 4wd engaged most of the day when I was driving around. No problems. Once engaged, it stayed engaged. Turned off the car, returned to it, started it and it was engaged.
mskalmus
05-28-2017 07:51 AM
adammtb
07-27-2015 11:57 AM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 4wd Issues - Delay in engaging
