4wd indicator light is flashing - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-25-2013, 11:52 AM   #1
b_stone81's Avatar
Okay so I have a 2001 4runner sr5 sport and I noticed my 4wd indicator light is flashing all the time. My 4lo still works fine but I can't tell if my 4hi works at all. The button on the side of the 4wd shifter is out (where my 4hi should be off) but I don't know if it is. It seems like the ride is getting worse. I tried tapping on both actuators and still nothing. Anyone know something else?
b_stone81 is offline   Reply With Quote
Old 03-25-2013, 11:59 AM   #2
250000_yota's Avatar
The light flashing indicates that the truck was unable to complete the shift from 4hi to 2hi and vice versa. You've probably got an actuator hanging up.
250000_yota is offline   Reply With Quote
Old 03-25-2013, 12:09 PM   #3
Philbert's Avatar
Philbert is offline   Reply With Quote
Old 03-25-2013, 12:34 PM   #4
b_stone81's Avatar
Well dang..... is there any way to fix that?
Old 03-25-2013, 12:41 PM   #5
Philbert's Avatar
LOL just don't do it in the future
A moderator will likely fix at some point.
Double posts are bad because you may not get all the answers you need because the right people may see one but not the other, etc. And they are annoying and make searching in the future for folks with your same problem more difficult.
Also, a good tip for anyone, since we can only see the title of your post and not the whole body when searching "new posts", try to have as much info as possible in your title (i.e. "4WD light flahses in 2001 4Runner...what does this mean?"). This way, someone who might know the answer and sees your title is more apt to click on the post, read it, and help you (and others in the future with the same issues).
Old 03-25-2013, 01:29 PM   #6
b_stone81's Avatar
Okay thanks for the tip
Old 03-25-2013, 02:08 PM   #7
b_stone81's Avatar
Anyone know how to fix my 4wd problem?
Old 03-25-2013, 03:34 PM   #8
Well I saw that you tried the tapping solution and it didn't come out, so one of the actuators is stuck good. You'll probably have to jack it up and get all four wheels off the ground to find out which one it is at this point.
Get it off the ground and start by turning the front tires. If the tire on the opposite side turns the oposite way the the front diff actuator isn't disengaging. Then check the driveshaft to the front wheels. If its still engaged in the transfer case it will be difficult if not impossible to turn by hand. While under there, you can also try tapping again because lifting it off the ground will also relieve the binding, and allow it to slip out of 4wd.
Old 03-25-2013, 03:39 PM   #9
b_stone81's Avatar
Okay ill try that and let you know how it goes. I perciate it
LED turn signals Shoua General Electrical & Lighting Related Topics 13 05-22-2016 06:19 AM
1992 Pickup 5VZ-FE Swap Done! Lingering questions for the experts nframe 3.4 Swaps 3 08-16-2015 10:03 AM
02 taco 4wd double cab front end clunk ripp96 95.5-2004 Tacomas & 96-2002 4Runners 0 07-25-2015 03:32 PM
Engine power loss/chugging until restart? ddg71 86-95 Trucks & 4Runners 1 07-24-2015 02:24 PM
Fuel Gauge Indicator Jumps shisha1999 84-85 Trucks & 4Runners 1 07-14-2015 12:09 AM
Tags
05, 06, 2005, 4lo, 4runner, 4wd, flashing, indicator, light, sequoia, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
