| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
4wd, first time in awhile!
#2 (permalink) |
nothing is wrong, but in the future, DO NOT engage your 4wd on hard pavement. there is no center diff like in an AWD vehicle so it will bind when you turn, and can break parts.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
Hmm, I guess then I have to go to some dirt to get everything moving again?
#4 (permalink) |
yes, only on loose or slippery surfaces. If you engage 4wd on pavement do not turn or it will bind.
__________________
2000 Taco SR5 V6 5speed TRD Airaid MIT Vortex muffler DEI 2-way Extang Tuff Tonno III |
#5 (permalink) |
Alright cool. So is that probably what all the squeeking was?
#6 (permalink) |
What can I do about oiling everything? Because I know it could use some love.
#7 (permalink) |
for the most part, you can just change the gear oil in the front differential. synthetic is good stuff but expensive and maybe not worth it in the front end if you don't run in 4wd a lot. you could always repack the wheel bearings and CV joints but that's usually something done as they wear out, not regular maintenace.
__________________
#8 (permalink) |
Alright cool. What is involved in changing the oil in the front differential? Any how to's? Sorry, again I am a beginner trying to learn, thanks for your patience.
#9 (permalink) |
Check out the "Tech write ups" section. You will find your info there.
__________________
2000 Taco SR5 V6 5speed TRD Airaid MIT Vortex muffler DEI 2-way Extang Tuff Tonno III Last edited by TACOMANATOR; 09-08-2005 at 08:32 PM. |
#10 (permalink) |
i've always thought it was ok to engage the 4wd on pavement to lube up the drive components ...as long as you are going straight.
__________________
04 Tacoma Double Cab V6 4x4 SAW 2.0's Alcan 8 pack Bilstein 5125's Ion 171's (-27mm bs) 32x11.50x15' BFG AT's |
#11 (permalink) | |
Quote:
__________________
- Joe 1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks 1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs |
#12 (permalink) |
just locking the hubs and driving will do a good job spinning everything in the front end around. my '79 owners manual recommends driving at least 10 miles per month with the hubs locked.
__________________
#13 (permalink) |
If I recall correctly, the owner's manual recommends driving in 4WD 1/month for about 10 miles to keep everything lubed. I habitually do that on a day when the roads are good and wet on a particular section of road that is primarily straight for those 10 miles. It worked well for over 200,000 miles on my '90...
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09 '08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks |
#14 (permalink) |
That recommendation always seemed like a good excuse to go wheeling to me...but hey, whatever you like!
__________________
www.toyotacrawlers.com '85 4runner: 4.7's, FoxFab sliders, custom bumpers, 1" body lift, F-150 springs rear, lockright, welded third, IFS rear axle, 1.5" wheel spacers, high-steer, rears up front, Longs, 38" SX's on steelies, 12Voltguy dual battery, soft top, BMW seats. NO LONGER lacking an engine. :D :D |
#15 (permalink) |
If he has locking hubs just put the transfer case in 4HI and leave the hubs unlocked. That will work the same as just locking the hubs. The problem I always had with just locking the hubs was I would forget them for a while which doesn't hurt anything except cause excess wear,but with the T/C in 4HI the little light stayed on as a reminder.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| All Time 4wd | AUYota | FJ Cruiser | 10 | 01-21-2007 09:06 PM |
| (3rd Gen) 4Runner - 4WD all the time or 2WD part of the time? | Galen | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 01-19-2007 04:49 PM |
| 2001/2002 Full Time 4wd, and 4wd systems | JHupp | 95.5-2004 Tacomas & 96-2002 4Runners | 21 | 03-09-2006 12:22 PM |
| Used 4WD for the 1st time... | rearviewmirror | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-10-2005 10:57 PM |
| full-time 4wd? | Nihil | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-09-2004 08:18 PM |
