4th Gen, rear light mod, feasibility ?!?
Old 03-09-2004, 07:12 PM
JGage's Avatar
While washing my truck the other day, I was thinking about what Woody said about his Hilux Surf having the rear fog/alert lights where our reflectors are located in the bumper.
I saw no way to remove them, readily (I break stuff, so I try not to mess around with things) btu I swear there is a space behind those reflectors.
Does anyone think it would be do able to mount some lights in/behind the glass(plastic ?) Maybe get some of the micro (eyeball) type lamps, drill out a big enough hole, and then epoxy the lamp into the drilled out hole. Or perhaps get someone to fabricate a something...
Am I like, waaayyy off base ?
Old 03-09-2004, 07:35 PM
Woodbert's Avatar
JGage,
Someone here did it. Biff maybe?
Old 03-09-2004, 08:07 PM
Biff's Avatar
Originally Posted by Woodbert
JGage,
Here is the Write Up its easy to do. Just make sure you get a good one inch drill bit. Also take your time, the light housing is very easily broken.
Old 03-10-2004, 05:15 AM
JGage's Avatar
Cool, but I meant white lights... Using those little eye fog lamps you see all over the place and drilling a hole through the plate... You could either tap into the reverse lights or have a switch on the dash ( I want that dash route.)
But, now I know it's do able... Thanks guys.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
Kalihi,HI
07-09-2015 04:29 PM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 4th Gen, rear light mod, feasibility ?!?
