4th gen binding when accel and turning
Old 04-15-2004, 06:23 PM
mud
mud's Avatar
I have an 04 v8 runner .When i am at acomplet stop and i accelerate and turn left or right i feel a little binding roughnes .Is that normal for fulltime 4weel. Does any body eleses do that .The center dif is not locked.
Old 04-15-2004, 07:21 PM
dcampen's Avatar
I haven't noticed this.
Old 04-15-2004, 08:44 PM
JGage's Avatar
define "binding" ? Sorry I have no idea... Mine is smooth as silk.
Old 04-15-2004, 08:55 PM
EDGE's Avatar
I think I understand what you mean, mine does the same thing probably a combination of the traction control and VSC tryin to keep the tires planted and not spinning on the turn, nothin to worry about, if it was really binding you would know it
Old 04-16-2004, 02:45 AM
mud
mud's Avatar
It happens between 0 and 10 mph you have to be turning fairly sharp left or right slight shake or jittery. Other wise smooth as silk except for my seat klunking around.
Old 04-16-2004, 04:42 AM
CTB
CTB's Avatar
Try a search on here...I believe some guys have come up with solutions to remedy this (that, or they have had the dealer fix it). Hopefully you can find something.
Old 04-16-2004, 10:36 AM
bulldog-yota's Avatar
How many miles does it have?
Check that the center diff is not locked!! EDIT: Sorry need to read more careful, but lock and unlock the center diff to make sure it works correctly.
I dont think you are referring to the the driveline clunck, which requires lube for the drivetrain.
Also take the seat back to the dealer and be very specifc in what words they put in the service order. If they dont fix it, take it back and get the exact smae works put in again. This way if they aren't able to fix it, you have a good lemon law case. See http://www.toyota-4runner.org/forumd...?s=&forumid=11 good board especially for 4th Gen and initial issues, from driveline clunking, moonroof ratlles to seat problems. Very useful.
Old 04-16-2004, 02:49 PM
mud
mud's Avatar
It has 6000 miles .Maybe its always done itand i just noticed it recently.
shisha1999
09-21-2015 08:22 PM
nick9455649
09-11-2015 05:10 PM
toofly1999
07-25-2015 07:09 PM
Backcountry411
07-24-2015 08:06 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: 4th gen binding when accel and turning
