4runner taco whip antenna mod? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-16-2009, 02:14 PM   #1 (permalink)
I was looking on 4runner.org (great site) because I'm thinking of replacing my power antenna on my 2000 limited with a whip one.
When I installed my amp though, I think I remember wiring the amp "on/off" to the antenna so that when the antenna goes up, the amp goes on. does this sound right? Anyways, where would I wire my amp if I didn't have this setup (ie installed a whip antenna)?
I assume it would be the same way taco owners do it (how is that?)...
thanks!
freeridethis206 is offline
Old 03-16-2009, 02:56 PM   #2 (permalink)
Yukon's Avatar
My antenna just connects to the HU, and it works, and the amp turns on when the HU turns on...
same way with stock amp
Yukon is offline
Old 03-16-2009, 10:31 PM   #3 (permalink)
98.T4R's Avatar
you need to wire it to switched ignition power ''also the same wire that turns the stereo on and off'' easy to find if you have a multi meter. if you search the web you should find wire diagrams for your vehicle. but if you installed an aftermarket stereo your amp needs to be wired to the solid blue wire and not the blue with white stripe
98.T4R is offline
Old 03-17-2009, 07:46 AM   #4 (permalink)
atistang's Avatar
if you hook it up to your antenna then the amp will probably only turn on when listening to fm, when you switch to a cd it will probably turn off
find something that only has power when the key is in accessory or on, like your radio switched power or wipers or power windows and use that for your signal for the amp
atistang is offline
Old 03-17-2009, 07:54 AM   #5 (permalink)
02_Limited's Avatar
Send a message via AIM to 02_Limited
My aftermarket HU keeps the antenna up no matter what input is being used (thanks to a ty installation job by a local car audio place). If I had and idea how to wire it just to AM/FM I would do it, but for now I will just deal with the antenna being up all the time
__________________
2002 Limited 4wd
Stuff
OME 881/906|OME N91SC/N86C|ToyTec diff drop|TRD catback|TRD plug wires|285 Terra Grapplers
color matched exterior|Andymod|Amber Hella 500's|LED tails|clear corners|black emblems|25% tint
Audio
TomTom|Infinity|Kicker 08ZX750.1/08CVR12|Jensen VM9412/iLink|Dynamat
Quote:
Originally Posted by habanero View Post
Throttle Positioning Spider?
02_Limited is offline
Old 03-17-2009, 11:07 AM   #6 (permalink)
scuba's Avatar
COOL HWHIP?
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 03-17-2009, 11:11 AM   #7 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
depends on your hu some will have a ant wire and some just have a remote amp wire which will turn the ant on in cd and radio mode you will want to just use that to turn your amp on
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 03-17-2009, 11:14 AM   #8 (permalink)
Elton's Avatar
in my case my antenna is broke soo i just unplugged it at the relay box and pushed it down to where i liked it i don't listen to radio much but it still gets good reception
__________________
Elton is offline
Old 03-19-2009, 09:01 AM   #9 (permalink)
atistang's Avatar
Quote:
your HU probably does put it down when you listen to cd, they probably just hooked your antenna up to the remote wire
if you have a wiring diagram with your HU then pull it out and see if they hooked it up to the power ant or the remote, your HU might not have a power antenna wire
atistang is offline
Tags
4runner, 4x4, amp, antenna, limited, mod, power, replace, setup, solid, taco, vm9412, whip, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tacoma Whip Antenna Mod Article Found! tmgallagher General Vehicle Related Topics (Non Year Related) 13 10-17-2009 09:37 AM
Write Up: The Taco Whip Antenna Mod Bob_98SR5 95.5-2004 Tacomas & 96-2002 4Runners 19 12-20-2002 05:39 PM
2009 InternetBrands, Inc.
