4Runner Sidemarker lamp/bulb replacement?
Old 10-27-2007, 10:58 AM
madmaxx's Avatar
I need to replace a bulb on my wifes 99 4Runner. I did an ulta-quick inspection, looks like the sidemarker assembly has to come out in order to change the bulb. Single screw up top is visible..but I know toyota, there has to be more
Anyone give me the locations and/or the removal procedure before I jump in there? Don't have a lot of time in order to turn wrenches anymore so it would be nice to know the battle plan beforehand.
Thanks!
James
Old 10-27-2007, 11:00 AM
pattycakes77's Avatar
you should only have to remove the screw on top and then pull it straight out towards the front of the car. i think there is a little expanding plug thingy that holds it in. you might have to pull kind of hard, at least on mine you do.
Old 10-27-2007, 12:46 PM
madmaxx's Avatar
Yep, that was it Simple as pie.
Thanks!
Old 10-27-2007, 01:40 PM
Elton's Avatar
yep its pretty simple its stuck on there pretty tight dont worry it wont break
toyota32
07-06-2015 05:42 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
yamaha73
06-18-2015 06:19 PM
Quick Reply: 4Runner Sidemarker lamp/bulb replacement?
