4runner Q's need answers ASAP!! HELP!
Old 07-08-2005, 08:48 AM
cracker_1's Avatar
Question 4runner Q's need answers ASAP!! HELP!
We are looking at a 99 SR5 4runner w/ the following:
-3.4/auto
-leather interior
-rear diff.lock
-285/16 MTR's
-no running boards
-color matching bumpers (not chrome)
-all service records included, timing belt changed at 80K
Can anyone enlighten me on the how to check the gear ratio in the diff.? What gears were available? To fit the current tires, was a lift necessary? The 4runner is in Texas, so we are making a road trip tomorrow to look at it. Anything else I should be looking for? TIA for your help.
CRACKER
Old 07-08-2005, 09:03 AM
4unner4life's Avatar
the gears on 99's with the locker is 4.30's and im pretty sure your going to be rubbing a whole lot with 285's and no lift, especially with the mtr's so your best bet is that he has a lift!
Old 07-08-2005, 09:08 AM
lee
lee's Avatar
yes, it HAS to have a lift of around 3" or so... maybe more.
surprised you cant tell by looking (or climbing in!)
Old 07-08-2005, 09:09 AM
cracker_1's Avatar
Thanks for the info. In the pictures provided, the tires have plenty of room to move, it doesn't look like they are rubbing anywhere. If it has a decent lift, that will cut my future work load down abit! (i.e. the wife will be happy )
Old 07-08-2005, 09:11 AM
cracker_1's Avatar
I have only seen pictures of the 4runner to date, we wil be doing a visual inspection tomorrow. The 4runner is in Texas, we are in Colorado.
Old 07-08-2005, 09:12 AM
lee
lee's Avatar
post up the pics!
Old 07-08-2005, 11:10 AM
rimpainter.com's Avatar
To check the ratio: Jack up the rear, mark the drive shaft where it enters the pumpkin, have someone rotate a tire exactly (2) times, count the number of revolutions on the shaft. Even the difference between 4.1 and 4.3 can be seen.
Old 07-08-2005, 12:44 PM
Flamedx4's Avatar
or... since it's an auto - start it up, put in gear. Mash the gas pedal to the floor. Time how long it takes to get to 60 mph. If it requires a calendar, the gears are stock. If only requires the hour hand, then the gears were changed... ;-)
Old 07-08-2005, 01:08 PM
cracker_1's Avatar
That is the way I would like to test it!!
The dealership has all of the records, so I will know tomorrow. If it is a slug, then I will wait to change the gears a little later on when I can afford to add a locker to the front as well. Does Toyota make a E-locker for the front??
Will post pics after we get the 4runner....
Old 07-08-2005, 02:36 PM
That's a big negative. The Landbruisers had a front locker, but I don't think that applies here.
MO transplant
04-23-2023 11:58 AM
deepmarsh
08-06-2015 03:44 AM
garagespace
07-09-2015 08:37 AM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 4runner Q's need answers ASAP!! HELP!
