4Runner 97 rear sag (question from Chile!!)
Hi, I am from Chile (South America) and a have a question for you guys!
I have a 1997 4Runner with "normal" rear springs (the originals with 100.000 miles) and RS9000 rear springs shocks.
My problem is that I have a rear sag problem (even when I drive only with 5 passengers without luggage!!)
I can’t buy a new set of OEM stiffer springs from USA (money problem ), but I can get a set from 1999-2003 4runner 3rd gen here.
My question is…. those ’99-2003 springs are stiffer than mine (‘97)?
Thanks!
Thanks!
From what I've read here (and I'm no expert), the '99 and '00 springs are one coil taller than the '96-'98 models. I believe in '01 that the springs are the same height as the '96-'98 models. The one coil should make the sag look less noticable or may even correct it.
I got a brand new set of stock springs from a 99-03 model installed on mine before I did my OME setup and I barely saw a difference at all. As far as I am concerned, they did nothing to solve the sag problem. If you can afford it at all I would go with the OME setup (you should be able to buy direct from Australia where that stuff is made). The other option would be to get some airbags to go inside the springs (I almost went this route) but the ride will be quite a bit stiffer in the rear when the vehicle is levelled out. They were also tough to find.....they seemed to have disappeared when I tried to buy them. In the end, I am glad I went the OME route.
....there are also the PP springs but I doubt they are available down there and they'd be a small fortune to ship.
https://www.yotatech.com/forums/f2/rear-springs-22981/
https://www.yotatech.com/forums/f2/4runner-sagging-37010/
https://www.yotatech.com/forums/f2/downeys-hds-performance-products-springs-6725/
they might be stiffer, but might not be
I bet if you can get some lower mileage ones you will be in good shape
so maybe find some lower mileage ones also wonder if some spring spacers can help you lift up the rear a little
Thanks guys! for all your answers.
I found in a junkyard a set of Toyota Prado rear springs. (Land Cruiser 90 series).
I know that this model is not available in USA… but, Does anybody knows something about the length or stiffness of those springs?
The top and bottom ends are identical.
Thanks again.
Thanks again.
Originally Posted by BOSTON4RUNNER
My friend is from Puerto Montt
we are heading to Chile soon for a surf trip
hello i am located in South Florida Miami area and we sale all products from ARB, Old Man Emu, and much more Australian products www.truckinmotion.com i recomend you to install the kit from OME since is going to give you a better ride quality and plus the lift will help you out as well when you go off road we can ship from US to you either directly or via Freight Forward company.
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
