4Runner 3.4L at 150K miles.. what to refresh? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-03-2006, 01:42 PM   #1 (permalink)
Gang
new to this site, not new to insanity forums. directed here by some idiot at TTROA.
I have an 00 4runner 3.4L that I bought brand new in '00. Just passed the 150,000 mile mark and want to refresh the beast for another 150K.
What should I do maintenance-wise? I read an article about replacing the front 02 Sensor irrespective of 'check engine' or whatever and I can believe it might need it.... still on the original. Should I, and which Brand/part num/etc?
The exhaust stinks like crazy, but the Cat passes all testing and runs at the right temp. Is it OK?
I assume its time to flush transmission, filter, etc?????
Why can I never seem to get the front end aligned "Just Right".... I have had it in repeatedly and it always comes back different, but not 'good'.... tires are in very good shape but the front end will pull a tad one way, then upon correction drift a bit the other way, and so it goes. it doesn't just track.
PLanning to FINALLY do the 4" Airbox Mod. I get lousy gas mileage.
Just ordered a new roof rack.... the original was flawed from the factory and lost all its paint in about 2 years flat.
Zapp22 is offline
Old 07-03-2006, 02:02 PM   #2 (permalink)
ebelen1's Avatar
Basic maintenance like plugs, wires, fuel filter, clean the maf, etc.
How about the timing belt (due at 90k) and while you're at it the water pump?
Flushing the trans w/ high mileage may make things worse so drop the pan first and make sure that there aren't metal pieces from your tranny before flushing.
How about the cooling system?
How about suspension (new springs, shocks, etc.)
There are many things you can do, these are just a few.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 07-03-2006, 06:37 PM   #3 (permalink)
ebelen
thx for your response.
I have the cash to do all of that: Which plugs? which wires?
Timing belt is ok [about 50K on the new one]
I am ignorant of water pump's propensity for failure.
the Tranny caveat is a good one.... that tracks with the old wisdom about such 'maintenance' that resulted in havoc. maybe replace fluid, replace filter?
z
Zapp22 is offline
Old 07-03-2006, 06:52 PM   #4 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
wires go with ngk i got a set for $37 bucks and i found that the dealer had plugs cheaper there denso i payed $17 bucks for 6
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 07-03-2006, 07:42 PM   #5 (permalink)
animator's Avatar
The vehicle not tracking right, or not wanting to go straight down the road or recenter the wheels could be a problem with the castor angle. It's something I would assume an alignment shop would check though...
animator is offline
Old 07-03-2006, 10:43 PM   #6 (permalink)
Check out this for starters: http://www.4x4wire.com/toyota/mainte...30k/index.html
You'll also want to look into flushing your brake fluid, and any other fluid that's old.
youngbuck is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
How many miles on your 3.4L timing belt? Tacotex 95.5-2004 Tacomas & 96-2002 4Runners 273 11-03-2009 01:06 PM
Used Tundra coils for 4runner lift, how many miles is too many miles? skjos 95.5-2004 Tacomas & 96-2002 4Runners 1 07-03-2007 09:52 PM
150k on 93-4Runner, Swap Engine? or not ROLANDF 95.5-2004 Tacomas & 96-2002 4Runners 22 12-29-2004 08:33 AM
How many miles out of a S/C'd 3.4L? zebra1550 95.5-2004 Tacomas & 96-2002 4Runners 1 12-08-2004 12:53 PM
150k 96redracer Maintenance & Repair Archives 3 01-27-2004 02:26 PM
2009 InternetBrands, Inc.
