4cyl Tach in a 6 cyl truck?
Old 03-07-2010, 12:34 PM
amocat95's Avatar
Hello,
If you put a tachometer from a 4 cylinder truck into a 6 cylinder truck is there a switch or chip that will correct the RPM levels? It revs like I'm driving an F1 car!
Any help would be greatly appreciated.
Thanks
Old 03-07-2010, 12:58 PM
brian2sun's Avatar
Some tachs have a switch on the back to choose the # of cylinders. Not sure if the OEM ones do.
Old 03-07-2010, 04:13 PM
amocat95's Avatar
I did not see a switch....any other thoughts?
Old 03-07-2010, 04:51 PM
eddieleephd's Avatar
try plugging it in to see if it will work right or not!! or after market tach...
Old 03-08-2010, 06:39 AM
EnolaGaia's Avatar
Originally Posted by amocat95
... If you put a tachometer from a 4 cylinder truck into a 6 cylinder truck is there a switch or chip that will correct the RPM levels? It revs like I'm driving an F1 car! ...
If we're talking OEM tachs and Tacomas - the answer is 'No'.
YotaLogic
12
11-17-2015 06:27 AM
bigblue82
10
07-06-2015 08:27 AM
MadMax48
07-03-2015 08:26 AM
streetuner15
06-18-2015 10:59 PM
Quick Reply: 4cyl Tach in a 6 cyl truck?
