4Crawler 1.5" Body lift installed! (pics)
Old 01-10-2009, 10:17 AM
pdyebrasil's Avatar
Hey everyone! I recently bought a 1.5" body lift from 4Crawler because I had some rubbing issues with my 295's and the SS 7.2 lift, mainly when I was fully flexed in the rear. I picked that height because I wasn't sure if the one inch was enough, but I thought that two inches would be too much.
The install went smoothly, but the biggest pain I ran into was getting the washers off of the stock bolts to remove them! Those things are really stuck on there! I really like how it turned out, and now I have no rubbing In the next little while I'll be making some gap guards to get rid of the gaps.
Onto the pictures!
NON-Flexed (better ones to come):
Before:
After:
Next to my sister's '99 limited, it is exactly 5" taller at the top of the wheel arches.
Next to a stock 96-98 4Runner:
Flexed:
Any comments and/or suggestions are always welcome
Old 01-10-2009, 10:24 AM
yoder519's Avatar
niceeeeee!!! you gotchur self a clean runner.
Old 01-10-2009, 10:33 AM
SpecialScottie's Avatar
I like your wheels
Old 01-10-2009, 01:43 PM
pdyebrasil's Avatar
Thanks guys. And whether the wheel comment was sarcastic or not, thanks FYI- they are Moto Metal 951s.
Old 01-10-2009, 01:48 PM
pattycakes77's Avatar
got any non flex pics?
Old 01-10-2009, 05:50 PM
JuJew's Avatar
I 2nd the non flexed request.
Would like to see how it sits on level ground. They are nice wheels and if you like them who cares. What size are they? back spacing? Only ask bc i would like to put that tire size on the stock 99 5 star wheels.
I have OME 881 and 890, which i think i similar in hight to the ss 7.1. I am ordering a 1.5 body lift for a similar setup like your are running.
Old 01-10-2009, 06:07 PM
danimal92sport's Avatar
To be honest, you might want to realign your bumper, it looks like the front of it is a little low.
Dan
Old 01-10-2009, 06:11 PM
toyospearo's Avatar
NICE 4 RUNNER!!
looks great and I like the wheels!
Old 01-10-2009, 07:19 PM
scuba's Avatar
Non flexed out before and after x2 edit er 3 ? !!
Old 01-10-2009, 07:32 PM
pdyebrasil's Avatar
It is a little lower than it was before (in relation to the body) but it looks much worse in that picture because of the shadow. The chrome reflects a little of the underside of the grille.
Old 01-10-2009, 07:35 PM
pdyebrasil's Avatar
Thanks man. The wheels are Moto Metal 951s... I am running 16" ones with i believe 4.5" backspacing, and I don't have any issues with the a-arms. With the stockers you might have to modify those though.
Old 01-10-2009, 09:11 PM
O.State4runner's Avatar
ever since i joined YotaTech, your 4Runner was the first I saw ... I love it man
Old 01-10-2009, 09:30 PM
sinister_rn61's Avatar
I'm thinking of adding a body lift to my 4runner as well. Any problems adding a body lift with an auto?
Old 01-11-2009, 10:15 AM
pdyebrasil's Avatar
Haha Thanks man, I quite like how it has turned out. I remember when you first joined as well...
Old 01-11-2009, 10:19 AM
pdyebrasil's Avatar
I guess it depends on how high you go, but 3rd gens are really simple. The only adjustment necessary for the transmission is I loosened the linkage adjustment bolt, then did the lift, and it had already shifted over to the new spot. So I just tightened it back up.
Other things that are necessary with 1.5"+ BL is the steering shaft extension, I lowered the radiator, and raised the front bumper. Really straightforward install. Roger Brown makes some quality parts
Old 01-11-2009, 01:40 PM
xcmountain80's Avatar
Nice!
Aaron
Old 01-18-2009, 06:25 PM
ThunderOne's Avatar
I didnt know they made a 1.5" BL.
Old 01-18-2009, 07:14 PM
crolison's Avatar
Its not flex until your driveshaft eats your gas tank
Old 01-19-2009, 04:44 AM
emptypockets's Avatar
Nice looking rig! I'm debating about a BL too and 1.5" seems like a good compromise between 1" and 2".
Old 01-19-2009, 07:47 AM
TEPUI's Avatar
excuse the Hijack, but would you mind pointing me to your headlight build thread? I can't find it!
Quick Reply: 4Crawler 1.5" Body lift installed! (pics)
